Hi, I have problems with nodemcu, as soon as I enter the Blynk.syncAll () command; the device disconnects and reconnects from the blynk server, but all this does not happen on me always with an identical code, I have tried more than one nodemcu but I always have the same problem someone has had the same problem? Thank you.
Smartphone Android
• Blynk Library version [v0.6.1]
#include <DHT.h>
char auth[] = “”;
char ssid[] = “”;
char pass[] = “”;
// Keep this flag not to re-sync on every reconnection
bool isFirstConnect = true;
// This function will run every time Blynk connection is established
BLYNK_CONNECTED() {
if (isFirstConnect) {
// Request Blynk server to re-send latest values for all pins
Blynk.syncAll();}}
#define DHTPIN 0
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
{ float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
Serial.println(“Failed to read from DHT sensor!”);
return;}
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
WidgetLED ledingresso(V1);
#define D0 16
#define D1 5 // I2C Bus SCL (clock)
#define D2 4 // I2C Bus SDA (data)
#define D3 0
#define D4 2 // Same as “LED_BUILTIN”, but inverted logic
#define D5 14 // SPI Bus SCK (clock)
#define D6 12 // SPI Bus MISO
#define D7 13 // SPI Bus MOSI
#define D8 15 // SPI Bus SS (CS)
#define D9 3 // RX0 (Serial console)
#define D10 1 // TX0
digitalWrite (D1,LOW);
digitalWrite (D2,LOW);
digitalWrite (D5,LOW);
dht.begin();
timer.run(); <
