Is it just me or is the stress relation to executing projects with blynk too much?
My nodemcu shows that it is online on my android app but the slider i added does not move my servo at all.
Even the value display i setup on the app that should show the current position of the servo does not work show anything.
I’m even more confused why it shouldn’t work, considering that it is the same code @mjrovai provided in his servo control project.
#define SW_VERSION "ServoCtrlBlynk_V.1"
/*NodeMCU */
char ssid [] = "<./>";
char pass [] = "1Firewall#@aadmin";
/* Blynk */
char auth [] = "20a8d9a65af94697b21fa1f2db5cb2da"; // Servo Control Project // Servo Control Project
/* OLED */
#include "SSD1306Wire.h"
#include "Wire.h"
const int I2C_DISPLAY_ADDRESS = 0x3c;
const int SDA_PIN = 5;
const int SCL_PIN = 4;
SSD1306Wire display(I2C_DISPLAY_ADDRESS, SDA_PIN, SCL_PIN);
/* Servo */
#define servo1Pin D2
#include <Servo.h>
Servo servo1;
/* Initial pot reading and servo position set the position to neutral */
#define potPin A0
int potReading = 1023/2;
int servo1Angle = 90;
/* Reads slider in the Blynk app and writes the value to "potReading" variable */
BLYNK_WRITE(V2)
potReading = param.asInt();
/* Display servo position on Blynk app */
BLYNK_READ(V1)
Blynk.virtualWrite(V1, servo1Angle);
void setup ()
servo1.attach(servo1Pin);
displaySetup();
// PotReading = analogRead(potPin); // Read Analog data from potenciometer not used here
servo1Angle = map(potReading, 0, 1023, 0, 180); // Map the pot reading to an angle from 0 to 180
servo1.write(servo1Angle); // Move the servo to a position
displayAngle();
delay (200);
/* Initiate and display setup data on OLED */
void displaySetup()
display.init(); // initialize display
display.clear(); // Clear display
display.display(); // Put data on display
/* Display Servo position */
void displayAngle()
display.clear();
display.setFont(ArialMT_Plain_16);
display.drawString(10, 0, "Servo Control");
display.drawString(0, 45, "POSITION:" );
display.setFont(ArialMT_Plain_24);
display.drawString(80, 40, String(servo1Angle));
display.display();
