My NodeMCU 1.0 seems like it’s not able to connect to Blynk, so it keeps on looping the code. It connects to my router normally through normal esp8266 code and the same goes for the Blynk code, but it stops at connecting to blynk-cloud.com:80 and spits out a bunch of stuff.
my Blynk library version is 1.3.2
I tried connecting through a mobile hotspot and through a VPN but it didn’t help.
I saw several places that maybe adding “blynk-cloud.com”, 8080" to my Blynk.begin could help but the outcome stayed the same with or without it
This is my code, it’s a simple example sketch.
#define BLYNK_TEMPLATE_ID "blahblahblah"
#define BLYNK_TEMPLATE_NAME "blahblahblah"
char auth[] = "blahblahblah";
char ssid[] = "UFO";
char pass[] = "blahblahblah";
Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 8080);
and it spits out this on the serial monitor:
9 i 4 [93] Connecting to UFO
[5423] Connected to WiFi
[5423] IP: 192.168.0.106
[5423]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.3.2 on ESP8266
#StandWithUkraine https://bit.ly/swua
[5549] Connecting to blynk-cloud.com:8080
[5606] Connecting to blynk-cloud.com:80
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Soft WDT reset
Exception (4):
epc1=0x40203180 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffe10 end: 3fffffd0 offset: 0160
3fffff70: 0000004f 000000bb 3ffeebf0 000015ac
3fffff80: 0000464f 3ffeeb48 00000000 40201fd8
3fffff90: 402076c0 6a00a8c0 feefeffe feefeffe
3fffffa0: feefeffe feefeffe feefeffe 3ffeed78
3fffffb0: 3fffdad0 00000000 3ffeed4c 4020435c
3fffffc0: feefeffe feefeffe 3fffdab0 40100e75
<<<stack<<<
then it loops with the same output every time.
