I’m currently working on a project where roller blinds in the bedroom are controlled with a nodeMCU ESP8622. Everything works, only the onboard LED (GPIO16, D0) just doesn’t want to go out. I don’t need the light in the bedroom.
I tried it with
pinMode (D0, OUTPUT);
digitalWrite (D0, HIGH);
to turn it off manually, but it doesn’t work. This code is definitely the right one for switching off the LED, because I also tested it individually in a sketch.
After a lot of trial and error, I found that
Blynk.begin (auth, ssid, pass);
switches on the LED permanently. Any code in the Blynk library pulls pin D0 to LOW. Is there a way to deactivate this on the software side?
