Hi, I’ve been trying to connect my NodeMCU with esp8266 but it doesn’t seem to work properly even though i used the example code without changing anything.
the serial monitor says:
[2617] Connecting to blynk-cloud.com:80
[4687] Login timeout
[7687] Connecting to blynk-cloud.com:80
[12691] Connecting to blynk-cloud.com:80
[17696] Connecting to blynk-cloud.com:80
[19701] Login timeout
Considering i’m still new with the NodeMCU and this is my first time using the esp8266 as well, what should i do to fix this problem?
Do you mean a NodeMCU which has an on board chip that says ESP8266 on it, or are trying to use an ESP8266 connected to your NodeMCU board to give Wi-Fi connectivity?
