new to this hope im posting in the right place and format…so my problem is blynk disconnects on me after i turn my phone screen off or i back out of the app and trys forever to reconnect i did some reading about this i tryed putting caps on the pwoerlines and simpletimer as well as blynk.run after blynk commands
#include <OneWire.h>
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#define Pin 14 //D5
#define Pin2 12 //D6
#define Pin3 13 //D7
#define OLED_RESET LED_BUILTIN
char auth[] = "36ca228ffb134e61b65b01a47745e45a";
OneWire ourWire(Pin);
OneWire ourWire2(Pin2);
OneWire ourWire3(Pin3);
DallasTemperature sensors(&ourWire);
DallasTemperature sensors2(&ourWire2);
DallasTemperature sensors3(&ourWire3);
float s1;
float s2;
float s3;
Adafruit_SSD1306 display(OLED_RESET);
const unsigned char PROGMEM hyrulebitmap[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00,
0x00, 0x03, 0xF8, 0x00, 0x00, 0x00, 0x03, 0x01, 0x80, 0xC0, 0x00, 0x00, 0x00, 0x1F, 0xC0, 0x00,
0x00, 0x03, 0xFE, 0xC0, 0x00, 0x00, 0x07, 0x03, 0xC0, 0xE0, 0x00, 0x00, 0x03, 0x7F, 0xC0, 0x00,
0x00, 0x03, 0xFF, 0xF6, 0x00, 0x00, 0x0F, 0x03, 0xC0, 0xF0, 0x00, 0x00, 0x6F, 0xFF, 0xC0, 0x00,
0x00, 0x03, 0xFF, 0xFF, 0xB0, 0x00, 0x1E, 0x07, 0xE0, 0x78, 0x00, 0x0D, 0xFF, 0xFF, 0xC0, 0x00,
0x00, 0x03, 0xFF, 0xFF, 0xFF, 0x80, 0x3C, 0x0F, 0xF0, 0x3C, 0x01, 0xFF, 0xFF, 0xFF, 0xC0, 0x00,
0x00, 0x03, 0xFF, 0xFF, 0xFF, 0xFC, 0x78, 0x0F, 0xF0, 0x1E, 0x3F, 0xFF, 0xFF, 0xFF, 0xC0, 0x00,
0x00, 0x03, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0x1F, 0xF8, 0x0F, 0xFF, 0xFF, 0xFF, 0xFF, 0xC0, 0x00,
0x00, 0x03, 0xFF, 0xFF, 0xFF, 0xFF, 0xE0, 0x1F, 0xF8, 0x07, 0xFF, 0xFF, 0xFF, 0xFF, 0xC0, 0x00,
0x00, 0x03, 0xFF, 0xFF, 0xFF, 0xFF, 0x40, 0x3F, 0xFC, 0x02, 0xFF, 0xFF, 0xFF, 0xFF, 0xC0, 0x00,
0x00, 0x00, 0x00, 0x3F, 0xFF, 0xFF, 0x80, 0x7F, 0xFE, 0x01, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0x00, 0x7F, 0xFE, 0x00, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0xFF, 0xFF, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x01, 0xFF, 0xFF, 0x80, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x03, 0xFF, 0xFF, 0xC0, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00,
0x00, 0x00, 0xBF, 0xFF, 0xFF, 0xFF, 0x07, 0xFF, 0xFF, 0xE0, 0xFF, 0xFF, 0xFF, 0xFD, 0x00, 0x00,
0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0x07, 0xFF, 0xFF, 0xE0, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00,
0x00, 0x00, 0xFF, 0xFF, 0xFF, 0xDF, 0x0F, 0xFF, 0xFF, 0xF0, 0xFB, 0xFF, 0xFF, 0xFF, 0x00, 0x00,
0x00, 0x00, 0x7F, 0xFF, 0xFF, 0x8F, 0x0F, 0xFF, 0xFF, 0xF0, 0xF1, 0xFF, 0xFF, 0xFE, 0x00, 0x00,
0x00, 0x00, 0x3F, 0xFF, 0xEC, 0x0F, 0x9F, 0xFF, 0xFF, 0xF9, 0xF0, 0x37, 0xFF, 0xFC, 0x00, 0x00,
0x00, 0x00, 0x1F, 0xFF, 0xC0, 0x07, 0x9F, 0xFF, 0xFF, 0xF9, 0xE0, 0x03, 0xFF, 0xF8, 0x00, 0x00,
0x00, 0x00, 0x0F, 0xF6, 0x00, 0x07, 0x80, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x6F, 0xF0, 0x00, 0x00,
0x00, 0x00, 0x05, 0xE0, 0x00, 0x1B, 0xC0, 0x00, 0x00, 0x03, 0xD8, 0x00, 0x07, 0xA0, 0x00, 0x00,
0x00, 0x00, 0x03, 0x00, 0x00, 0xFF, 0xE0, 0x00, 0x00, 0x07, 0xFF, 0x00, 0x00, 0xC0, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xE0, 0x01, 0x80, 0x07, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xF0, 0x00, 0x00, 0x0F, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0x7F, 0xFE, 0xFC, 0x03, 0xC0, 0x3F, 0x7F, 0xFE, 0xC0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x1F, 0xFF, 0xFC, 0x3E, 0x03, 0xC0, 0x7C, 0x3F, 0xFF, 0xF8, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x1F, 0xFF, 0xE0, 0x3F, 0x87, 0xE1, 0xFC, 0x07, 0xFF, 0xF8, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x0F, 0xFF, 0xE0, 0x1F, 0xC7, 0xE3, 0xF8, 0x07, 0xFF, 0xF0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x07, 0xFF, 0x00, 0x1F, 0x8F, 0xF1, 0xF8, 0x00, 0xFF, 0xE0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0xFF, 0x00, 0x7E, 0x1F, 0xF8, 0x7E, 0x00, 0xFF, 0xC0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x01, 0xF8, 0x00, 0x7E, 0x1F, 0xF8, 0x7E, 0x00, 0x1F, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0xF8, 0x01, 0xFC, 0x3F, 0xFC, 0x3F, 0x80, 0x1F, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xF8, 0x3F, 0xFC, 0x1F, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xF8, 0x7F, 0xFE, 0x1F, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xF0, 0x0F, 0xF0, 0x0F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xF3, 0x87, 0xE1, 0xCF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xE7, 0xC3, 0xC3, 0xE7, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x43, 0xC2, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x81, 0x81, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x03, 0xC0, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x0F, 0xF0, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x1F, 0xFE, 0x07, 0xE0, 0x7F, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFE, 0x07, 0xE0, 0x7F, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFE, 0x07, 0xE0, 0x7F, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0x03, 0xC0, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x0F, 0x03, 0xC0, 0xF0, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x78, 0x0E, 0x03, 0xC0, 0x70, 0x1E, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x5C, 0x1C, 0x01, 0x80, 0x38, 0x3A, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x18, 0x01, 0x80, 0x18, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x7C, 0x00, 0x01, 0x80, 0x00, 0x3E, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x3C, 0x00, 0x01, 0x80, 0x00, 0x3C, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x1E, 0x00, 0x01, 0x80, 0x00, 0x78, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x01, 0x80, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
const unsigned char sheath2 [] = {
0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0x48, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x12,
0x48, 0x00, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, 0x00, 0x12,
0x4E, 0x03, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, 0xC0, 0x72,
0x47, 0xFF, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0xFF, 0xE2,
0x40, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x02,
0x70, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x00, 0x0A,
0x54, 0x01, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x80, 0x3A,
0x44, 0x21, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x84, 0x22,
0x74, 0x71, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x8E, 0x2E,
0x44, 0xF9, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x9F, 0x22,
0x7D, 0x05, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xA0, 0xBE,
0x43, 0x8E, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x71, 0xC2,
0x47, 0xDF, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0xFB, 0xE2,
0x50, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x00, 0x0A,
0x5F, 0xFF, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B, 0xFF, 0xEA,
0x40, 0x20, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x04, 0x02,
0x70, 0x20, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x04, 0x0E,
0x58, 0xF8, 0xD0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B, 0x1F, 0x1A,
0x46, 0x23, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0xC4, 0x62,
0x7E, 0x73, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xCE, 0x7E,
0x47, 0x07, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0xE0, 0xE2,
0x5F, 0x8F, 0xD0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B, 0xF1, 0xFA,
0x41, 0xDC, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x3B, 0x82,
0x46, 0xAB, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0xD5, 0x62,
0x40, 0xA8, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x15, 0x02,
0x4B, 0x26, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, 0x64, 0xD2,
0x46, 0x73, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0xCE, 0x62,
0x60, 0xA8, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x15, 0x06,
0x70, 0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x00, 0x0A,
0x5C, 0x01, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, 0x80, 0x32,
0x53, 0x06, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x60, 0xCA,
0x61, 0x8C, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x31, 0x86,
0x58, 0xD8, 0xD0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x1B, 0x1A,
0x50, 0x50, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x0A, 0x0A,
0x47, 0xDF, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0xFB, 0xEA,
0x5D, 0xDD, 0xD0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B, 0xBB, 0xBA,
0x61, 0xDC, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x3B, 0x86,
0x63, 0xAE, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0x75, 0xC6,
0x67, 0x27, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xE4, 0xE6,
0x7F, 0xAF, 0xD0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xF5, 0xFA,
0x47, 0x27, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0xE4, 0xE2,
0x4F, 0x27, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x09, 0xE4, 0xF2,
0x6E, 0x73, 0xB0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0D, 0xCE, 0x76,
0x7E, 0x23, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0xC4, 0x7E,
0x41, 0xFE, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x3F, 0xC2,
0x20, 0xF8, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x1F, 0x04,
0x10, 0x70, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x0E, 0x08,
0x0B, 0x8E, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x71, 0xD0,
0x04, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x20,
0x02, 0x22, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x44, 0x40,
0x01, 0x74, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2E, 0x80,
0x00, 0xA8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x15, 0x00,
0x00, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x00,
0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00
Blynk.begin(auth, "****","****");
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.drawBitmap( 0, 0, hyrulebitmap, 128, 64, WHITE);
display.display();
delay(2000);
sensors.begin();
sensors.setResolution(10);
sensors2.begin();
sensors2.setResolution(10);
sensors3.begin();
sensors3.setResolution(10);
timer.setInterval(2000L, ReadTemp);
timer.setInterval(3000L, Display);
void ReadTemp()
s1 = sensors.getTempFByIndex(0);
sensors2.requestTemperatures();
s2 = sensors2.getTempFByIndex(0);
sensors3.requestTemperatures();
s3 = sensors3.getTempFByIndex(0);
BLYNK_READ(V1)
Blynk.virtualWrite(V1, s1);
BLYNK_READ(V2)
Blynk.virtualWrite(V2, s2);
BLYNK_READ(V3)
Blynk.virtualWrite(V3, s3);
void Display()
display.drawBitmap( 0, 0, sheath2, 128, 64, WHITE);
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(35,7);
display.println(s1);
display.setCursor(35,28);
display.println(s2);
display.setCursor(35,49);
display.println(s3);
display.display();
yield();
