I have an issue with a setup which consists of:
NodeMCU 1.0
DHT22 Sensor
Local Raspberry Blynk Server
Versions used:
Blynk library used: 0.3.7
Local Rpi server version: 0.16.2
The following program is from instructables, slightly modified:
If i let without the isnan() check of DHT22 read values, i get Nan for both temperature and humidity as well sometimes, and after a while i get only Nan-s on the virtual ports.
Hardware images:
#include <DHT.h >
#define DHTPIN 13 //pin gpio 13 in sensor
#define DHTTYPE DHT22 // DHT 22 Change this if you have a DHT11
DHT dht(DHTPIN, DHTTYPE);
char auth[] = "xxx"; // Put your Auth Token here. (see Step 3 above)
Blynk.begin(auth, "xxx", "yyy", IPAddress(192,168,0,4));
// Setup a function to be called every 10 seconds
timer.setInterval(10000L, sendUptime);
void sendUptime()
//Read the Temp and Humidity from DHT
float h = dht.readHumidity();
//t or h sometimes is nan, do not send nan value to blynk
// h and t is nan bc. of the blynk libraty and not from the dht library!!!!!
// Test out to remove every blynk function call, and check serial port
if(isnan(h) || isnan(t))
Serial.print(F("Failed to read from DHT sensor!\r\n"));
Blynk.virtualWrite(10, t); // virtual pin
Blynk.virtualWrite(11, h); // virtual pin
Serial.print(F("Everything should be fine, reading transmitted\r\n"));
Blynk.run(); //When i comment this line, seems like the readHumidity and ReadTemperature works each time
Connecting to the serialPort i saw the following messages:
Serial output with blynk.run() uncommented
*- After a while i get only
Serial output with Blynk.run() commented out
For me it seems like for some reason the Blynk.run() influences the reading from the DHT22 sensor.
