I have NODEMCU ESP8266 and Blynk project. Everything works fine.
The only problem is that Blynk library in Arduino IDE controls built-in LED.
It blinks every 1or 2 seconds.
How can I avoid this?
Regards.
Regards.
Which version of the NodeMCU are you using, and what code are you running?
Your code or App Widgets control the LED, not the Library.
Used hardware NODEMCU ESP8266 v1.0.
Here is the code:
char auth[] = " "; //Enter the Auth code which was send by Blink
char ssid[] = " "; //Enter your WIFI Name
char pass[] = " "; //Enter your WIFI Password
#define DHTPIN 2 // Digital pin 4 (actually D4)
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
dht.begin();
I fixed your post to properly format the posted code.
Please follow the directions on how to do so in the future…
Digital pin 2 (AKA GPIO 2, AKA D4) is tied to the built in LED… so I recommend you use another pin instead.
Thank you. I’ll try and will post result here.
Regards.
Now it works correct.
Thank’s.
