I’d need to see the sketch and the copied/pasted error message from the compiler, but it sounds like your Blynk libraries may not be installed correctly.
#include <BlynkTimer.h>
char auth[] = "eYOJ9pkawJlSNzDLlOPUd7RkipGWHvqO";
/* WiFi credentials */
char ssid[] = "ZONG MBB-E8231-6E63";
char pass[] = "electroniclinic";
int mq135 = A0; // smoke sensor is connected with the analog
int data = 0;
timer.setInterval(1000L, getSendData);
timer.run(); //
* Send Sensor data to Blynk
void getSendData()
data = analogRead(mq135);
Blynk.virtualWrite(V2, data); //virtual pin V3
if (data > 600 )
Blynk.notify("Smoke Detected!!!");
Sir pls reply
Well, if there is a fire detected then the “Smoke Detected!!!” notification will be sent once every second - until the smoke detector reading falls to 600 or less.
To overcome this you should use a variable as a flag to indicate that a notification has been sent already, and check this before sending another notification. The flag should be reset once the reading is 600 or below again.
Also, I’m a fan of using descriptive variable names such as “smoke-level” rather than “data”, and a function name of “take_smoke_level_reading” rather than “getSendData”.
Would you sendsome example program that contains BlynkTimer in it.so that I can get some idea about how to use .
Multiple libraries were found for " BlynkSimpleEsp8266.h"
2_gas:3:23:fatal error:BlynkTimer.h:No such file or directory
Used: C:\Users\india\Documents\Arduino\libraries\blynk-library-0.6.1
#include<BlynkTimer.h>
Not used: C:\Users\india\Documents\Arduino\libraries\Blynk. ^
compilation terminated.
exit status 1
BlynkTimer.h:No such file or directory```
Sir pls give solution to this problem
You are already using it in your sketch, in the correct way.
Without some context this means nothing.
I edit and shared it sir,pls reply
I’d guess that your Blynk library isn’t correctly installed.
