Hi, im trying to connect 4 ds18b20 sensors to my NodeMCU 1.0 but im having problem with decimals. Its currently just displaying a whole number like 32°C. I have tried changing the sensors resolution but doesnt appear to make a difference. I have looked all over the forum but cant find a solution, what am i doing wrong here?
#include <OneWire.h>
#define ONE_WIRE_BUS 2 // This is the ESP8266 pin
DeviceAddress tempSensor1 = { 0x28, 0xFF, 0x34, 0x1C, 0x00, 0x16, 0x03, 0x5D }; // Temperature probe #1
DeviceAddress tempSensor2 = { 0x28, 0xFF, 0x02, 0x65, 0x00, 0x16, 0x03, 0x7E }; // Temperature probe #2
DeviceAddress tempSensor3 = { 0x28, 0xFF, 0x42, 0x1A, 0x00, 0x16, 0x03, 0xA5 }; // Temperature probe #2
DeviceAddress tempSensor4 = { 0x28, 0xFF, 0x92, 0x14, 0x00, 0x16, 0x03, 0xEE }; // Temperature probe #2
char auth[] = "0952dd6d3dd146e0a73c428b7d14d793";
char ssid[] = "ddd";
char pass[] = "ddd";
int temperature1, temperature2, temperature3, temperature4; // Variables for storing temperatures
// Wait until connected
sensors.begin();
sensors.setResolution(tempSensor1, 10); // More on resolutions: http://www.homautomation.org/2015/11/17/ds18b20-how-to-change-resolution-9101112-bits/
sensors.setResolution(tempSensor2, 10);
sensors.setResolution(tempSensor3, 10);
sensors.setResolution(tempSensor4, 10);
// These timers are used to keep the loop() nice and leak... keeps Blynk from getting flooded.
timer.setInterval(5000L, sendSensor1);
timer.setInterval(15000L, sendSensor2);
timer.setInterval(30000L, sendSensor3);
timer.setInterval(50000L, sendSensor4);
void sendSensor1() {
sensors.requestTemperatures(); // Polls the sensors
temperature1 = sensors.getTempC(tempSensor1); // Stores temp in F. Change getTempF to getTempC for celcius.
Blynk.virtualWrite(1, temperature1(); // Send temp to Blynk virtual pin 1
void sendSensor2() {
temperature2 = sensors.getTempC(tempSensor2);
Blynk.virtualWrite(2, temperature2);
void sendSensor3() {
temperature3 = sensors.getTempC(tempSensor3);
Blynk.virtualWrite(3, temperature3);
void sendSensor4() {
temperature4 = sensors.getTempC(tempSensor4);
Blynk.virtualWrite(4, temperature4);
