I am running a DHT11 sensor on NodeMCU connected to Blynk. I attempted to report the sensor data (temperature only) after a request from Google Assistant through IFTTT. I found this doc. I tried to replace “blynk-clound” with the corresponding IP address. Nothing worked and I can’t get Google Assistant to report the temperature.
From my understanding, IFTTT can only execute commands by changing the state of the pin.
Is there a way to achieve this goal?
Thank you!
