I have a NodeMCU connected to a RFID-RC522 with a local Blynk server on a Raspberry Pi.
When a tag is scanned a red or green led is lit depending on the tag. and the tag and result sent to the Blynk app on my tablet via a virtual pin
This is working just fine.
What I am trying to do is use the reporting module to export a history of tags, result and date/time, but when I run the report on the virtual pin there is no data to export.
Code below.
//RFID Declarations
#include <RFID.h>
#define SS_PIN D4
#define RST_PIN D3
RFID rfid(SS_PIN, RST_PIN);
bool access = false;
String cardno = "";
int numRows = 0;
//Maximum of 15 records.
String rfids[][3]
{"7076987", "Purple Dragon", "no"},
{"24186131", "Mad Gunslinger", "yes"},
{"1364139128", "Elsa", "no"},
{"1364236158", "Darth Maul", "no"},
{"19415315163", "Copper Dragon", "no"},
{"166124109203", "Tree Monster", "yes"},
{"136436117", "Leia", "no"},
{"13644475", "Luke", "yes"},
#include <ESP8266WebServer.h>
const char* ssid = "SSID";
const char* password = "password";
ESP8266WebServer server(80);
String page = "";
//LED Declarations
int RedLED = D2;
int GrnLED = D1;
//End LED
//Blynk
char auth[] = "AuthToken";
String token;
String msg;
//RFIDSetup
Serial.println("SPI Start");
SPI.begin();
Serial.println("Init RFID");
rfid.init();
numRows = sizeof(rfids) / sizeof(rfids[0]);
Serial.print("Number of rows = ");
Serial.println(numRows);
Serial.println(ssid);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
Serial.println("");
// Start the server
server.begin();
Serial.println("Server started");
// Print the IP address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP()); //Gets the WiFi shield's IP address and Print the IP address of serial monitor
Serial.println("/");
//LED Setup
pinMode(RedLED, OUTPUT);
pinMode(GrnLED, OUTPUT);
Blynk.begin(auth, ssid, password, IPAddress(10,10,0,117), 8080);
msg = "Server started";
cardRead();
server.handleClient();
void cardRead()
token="";
if(rfid.isCard())
if(rfid.readCardSerial())
int IDlen = 4;
cardno = "";
for(int i = 0; i < IDlen; i++)
cardno += rfid.serNum[i];
Serial.print("Card - ");
Serial.println(cardno);
for(int x = 0; x < numRows; x++)
access = false;
if(cardno != rfids[x][0])
access = false;
if (rfids[x][2] == "yes")
access = true;
token = rfids[x][1];
break;
access = false;
break;
accessAction();
void accessAction(){
//CheckAccess
if(access)
msg = token + " - allow";
Blynk.virtualWrite(V5, msg);
Blynk.syncAll();
digitalWrite(GrnLED, HIGH);
Serial.println(msg);
delay(2000);
digitalWrite(GrnLED, LOW);
msg = token + " - deny";
//Flash Red LED
Blynk.syncAll();
for (int i = 0; i <= 5; i++){
digitalWrite(RedLED, HIGH);
delay(100);
digitalWrite(RedLED, LOW);
delay(100);
server.on("/", [](){
page = "<h1>Sensor to Node MCU Web Server</h1><h3>Data:</h3> <h4>"+String(msg)+"</h4>";
server.send(200, "text/html", page);
