Hi, in this project I am trying to use the NodeMCU Amica development board to carry out laboratory tests.
This is the photo of the module I’m testing.
As I already said, I compile and load the sketch without error, one messages appear on the serial monitor “[239] Connecting to CLEMENTE.NET”
and, not happens nothing, The WiFi module LED remains off.
Is there anyone who has already solved this problem and can give me a hand?
This is the sketch I am trying
Download latest Blynk library here:Blynk is a platform with iOS and Android apps to control
projects by simply dragging and dropping widgets.Downloads, docs, tutorials: http://www.blynk.cc Sketch generator: http://examples.blynk.cc Blynk community: http://community.blynk.cc Social networks: http://www.fb.com/blynkapp http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools → Board menu!Change WiFi ssid, pass, and Blynk auth token to run
Feel free to apply it to any other example. It’s simple!
*************************************************************//* Comment this out to disable prints and save space */
#include <BlynkSimpleEsp8266.h>// You should get Auth Token in the Blynk App.
char auth = “****************************************”;// Your WiFi credentials.
// Set password to “” for open networks.
char ssid = “CLEMENTE.NET”;
char pass = “**************************”;void setup(){
Serial.print(“Started!”);
if (Blynk.connected()) Serial.print(“BLYNK connesso”); else Serial.print(“BLYNK non connesso”);
}void loop(){
Serial.print(“.”);
