Thanks for these instructions. Like to use onoff for the reasons you have stated rather than go the WiringPi route. However, when following the instructions to the letter, I do still get a problem with onoff.
All software is installed OK and have valid version numbers.
When I call onoff in my script:
var onoff = require('/usr/lib/node_modules/onoff');
and run node:
sudo NODE_PATH=/usr/lib/node_modules node ./test3.js
I get the following error:
/usr/lib/node_modules/onoff/node_modules/bindings/bindings.js:96
throw err
Error: Could not locate the bindings file. Tried:
→ /usr/lib/node_modules/onoff/node_modules/epoll/build/epoll.node
→ /usr/lib/node_modules/onoff/node_modules/epoll/build/Debug/epoll.node
→ /usr/lib/node_modules/onoff/node_modules/epoll/build/Release/epoll.node
→ /usr/lib/node_modules/onoff/node_modules/epoll/out/Debug/epoll.node
→ /usr/lib/node_modules/onoff/node_modules/epoll/Debug/epoll.node
→ /usr/lib/node_modules/onoff/node_modules/epoll/out/Release/epoll.node
→ /usr/lib/node_modules/onoff/node_modules/epoll/Release/epoll.node
→ /usr/lib/node_modules/onoff/node_modules/epoll/build/default/epoll.node
→ /usr/lib/node_modules/onoff/node_modules/epoll/compiled/6.12.0/linux/arm/epoll.node
at bindings (/usr/lib/node_modules/onoff/node_modules/bindings/bindings.js:93:9)
at Object.<anonymous> (/usr/lib/node_modules/onoff/node_modules/epoll/epoll.js:1:99)
at Module._compile (module.js:570:32)
at Object.Module._extensions..js (module.js:579:10)
at Module.load (module.js:487:32)
at tryModuleLoad (module.js:446:12)
at Function.Module._load (module.js:438:3)
at Module.require (module.js:497:17)
at require (internal/module.js:20:19)
at Object.<anonymous> (/usr/lib/node_modules/onoff/onoff.js:4:27)
If I run default Blynk client:
export PATH=$PATH:/opt/nodejs/bin/
unset NODE_PATH
blynk-client MyAuthToken
I get the following when I press a GP button on and then off in the app:
Connecting to: blynk-cloud.com 8441
SSL authorization...
Connected
Authorized
Blynk ready.
No direct pin operations available.
Maybe you need to install mraa or onoff modules?
^C
Calling node-dht-sensor works fine and my 2 sensors are read correctly into Blynk app.
I wish to use onoff to control some relays.
I have a Raspberry Pi 3b running Rapbian v9 (Stretch) and use the Blynk cloud service.
Do you have any suggestions how to fix this?
