Node Red 'set multiple properties (by code)' of Blynk widget not working
node-red v3.1.1 running on raspberry pi
node-red-contrib-blynk-iot 1.0.0
I am not able to set multiple properties for a Blynk widget using the ‘set property’ node.
I have read the documentation on msg.color and msg.label etc…however, I am unable to get this to work.
Any help would be greatly appreciated.
Regards,
Anand.
I do n’t personally use the “Set multiple properties (by code)” option in any of my flows, so can’t say whether this works or not.
But, it would help if you explained what type of widget you were setting the properties for, which properties you’re trying to set, and how you are doing your testing.
I managed to get the feature to work.
We need to send a msg.payload along with msg.color and msg.label etc…even is the msg.payload is blank.
All works well.
Regards,
Anand.
