Hi, After working with Timer input widget for over a year, I’m still wonder why widget returns values same as when select all days.
It confuse user when selecting days for timer. No selected means NO days selected. All days selected means ALL days selected.
Blynk, you could return Zero (0) if no days selected, this make sense for programmers and users.
Hey man, this is a well documented issue with the Time input widget and has been covered many times in other posts. Theses also contain the necessary solution to correct the issue.
For the future, I would recommend that you search the forum for similar issues before you create a post - as it says to do when you create one.
