can you please consider the following situation :
- add a switch widget and connnect it to a virtual pin
- set the ‘label’ property of the widget with any string
the height of the switch will be reduced to allow the label string to be displayed
after this, there is no way to remove the label display, I tried :
- sending an empty string label
- removing the widget and re-create it
- removing the datastream an re-create it
but the switch always kept a reduced size, leaving room for a blank label
this is very embarassing when a label has been sent by error or is no more needed
it seems to be the same with all widgets accepting the label property
is there a workaround ?
thank you
Bruno
