#include <Blynk.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <WiFiUdp.h> // For OTA
#include <ArduinoOTA.h> // For OTA
#include <OneWire.h>
#include <LiquidCrystal_I2C.h> // Library for LCD
#include <Wire.h>
#define ONE_WIRE_BUS 13
//#define I2C_SDA_PIN 21 // Using GPIO21 for SDA pin
//#define I2C_SCL_PIN 22 // Using GPIO22 for SCL pin
#define WATER_PUMP_PIN 12 // Replace 12 with the actual pin number you are using for the water pump relay
#define BLYNK_TEMPLATE_ID "TMPL6dyKizI97"
#define BLYNK_TEMPLATE_NAME "SMART FARMING 2"
#define BLYNK_AUTH_TOKEN "94udGHGv3SN4_uGwYAsOMNiNbYbyMzuE"
#define moisture_sens 34 // Analog pin for soil moisture sensor
#define VPIN_SENS V0 // Blynk virtual pin for soil moisture level
//#define LCD_ADDRESS 0x27 // I2C address for the LCD
//#define LCD_ROWS 2 // Number of rows on the LCD
//#define LCD_COLUMNS 16 // Number of columns on the LCD
char auth[] = "94udGHGv3SN4_uGwYAsOMNiNbYbyMzuE"; // Auth Token in the Blynk App
char ssid[] = "Redmi"; // WiFi SSID
char pass[] = "1234567890"; // WiFi password
LiquidCrystal_I2C lcd(0x27, 16, 2);
int sens1_value = 0;
int outputvalue1 = 0;
bool pumpRunning = false;
unsigned long pumpStartTime = 0;
const unsigned long pumpDuration = 3000; // 3 seconds
const unsigned long pumpStopTime = 3000; // 3 seconds
void sendSensor()
// Request temperature from all devices on the data line
float tempC = sensors.getTempCByIndex(0);
int moistureValue = analogRead(moisture_sens);
int moistureLevel = map(moistureValue, 0, 4095, 100, 0); // Reverse the mapping to get accurate moisture level
Serial.print("Celsius temperature: ");
Serial.print(tempC);
Serial.print(" - Moisture Level: ");
Serial.print(moistureLevel);
Serial.println("%");
// Display temperature and moisture level on the LCD
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Temp: ");
lcd.print(tempC);
lcd.print("C");
lcd.setCursor(0, 1);
lcd.print("Moisture: ");
lcd.print(moistureLevel);
lcd.print("%");
// Send temperature and moisture level to Blynk
Blynk.virtualWrite(V1, tempC);
Blynk.virtualWrite(V2, moistureLevel);
sensors.begin();
Wire.begin ( 21, 22); // Initialize the I2C interface with the chosen pins
lcd.begin(16,2); // Initialize the LCD display with the specified number of columns and rows
lcd.setBacklight(HIGH);
pinMode(WATER_PUMP_PIN, OUTPUT); // Set the water pump pin as an output
ArduinoOTA.begin(); // For OTA
timer.setInterval(100L, sendSensor);
ArduinoOTA.handle(); // For OTA
unsigned long currentMillis = millis();
if (!pumpRunning && outputvalue1 < 66) {
// Soil moisture level is low and pump is not running, start the pump
pumpRunning = true;
pumpStartTime = currentMillis;
digitalWrite(WATER_PUMP_PIN, HIGH);
} else if (pumpRunning && currentMillis - pumpStartTime >= pumpDuration) {
// Pump has been running for the desired duration, stop the pump
digitalWrite(WATER_PUMP_PIN, LOW);
delay(pumpStopTime); // Wait for the specified stop time before checking moisture level
} else if (!pumpRunning && outputvalue1 >= 70) {
// Soil moisture level is high and pump is not running, stop the pump
this is the code for my smart farming system project. Upon compiling the code, i got errors which says:
"Arduino: 1.8.19 (Windows 10), Board: “DOIT ESP32 DEVKIT V1, 80MHz, 921600, None, Disabled”
C:\Users\Aiman\Desktop\FYP\Coding\smart farming system 2\sketch_may06d\sketch_may06d.ino: In function ‘void setup()’:
sketch_may06d:88:17: error: no matching function for call to ‘LiquidCrystal_I2C::begin(int, int)’
In file included from C:\Users\Aiman\Desktop\FYP\Coding\smart farming system 2\sketch_may06d\sketch_may06d.ino:10:
C:\Users\Aiman\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note: candidate: ‘void LiquidCrystal_I2C::begin()’
void begin();
C:\Users\Aiman\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master/LiquidCrystal_I2C.h:76:7: note: candidate expects 0 arguments, 2 provided
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
can anyone help me to solve it?
