I’ve made my firt project: a simple led on/off. it works fine using the APP and console.
I just added a TIMER on the app (no available on console) but I can’t select the datastream because the app tell me to go to the device template and set up datastreams on the dashboard. But I have allready done it. So button has its one, and I can add a led and select the datastream and it works fine.
Why all the other objects can be connected with a datastream but TIMER doesn´t?
I use Iphone, esp8266 and last version of blynk 3.4.6
Thanks!
First of all, there is no longer a Timer widget available in Blynk IoT, it has been replaced with Automations.
The widget that is available within Blynk IoT, and the one that I’m guessing you’ve selected is the Time Input widget. This is very similar to the Time Input widget that was available within Blynk Legacy, and which is much more complex to use (but is also much more powerful) compared to the old Legacy Timer widget.
The Time Input widget requires a virtual datastream with a String data type. The Start time, Stop time, days of the week selected and timezone offset are embedded within this string array, and need to be extracted and compared to the current time to decide whether or not to turn your device on or off.
I’d suggest that you take a look at Automations instead:
I have been investigating Automations. I could program an automation to “Swich Control” at a fixed time zone. And it works but ony when button is ON, then it turns OFF and my led do the same: turns off.
But if the led is off, at the time programmed on the Automation, the Swich Control does not change to ON. I do not understand why Swich Control ony works i one direction.
You need to provide more information about the automation you’ve created and the datastream that it’s attached to, along with the code you’re running on your device.
Well I followed the steps creating the automation on the console. By now only 1 step trying to change the position of the button. If it is on, turn off. If it is off, turn on.
But only change if the button is ON.
This is a simple demo of sending and receiving some data.
Be sure to check out other examples!
#define BLYNK_TEMPLATE_ID "************"
#define BLYNK_DEVICE_NAME "Quickstart Template"
#define BLYNK_AUTH_TOKEN "*************"
char ssid[] = "***********";
char pass[] = "**********";
const int ledPin = 5; // 5 és el D1,
void myTimerEvent()
Blynk.virtualWrite(V2, millis()/1000);
//Blynk.sendInternal("rtc", "sync"); //request current local time for device
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt(); // Valor de l'interruptor1 ON 2 OFF
Serial.print(value);
if(value == 1) {
// execute this code if the switch widget is now ON
digitalWrite(ledPin,HIGH); // Set digital pin 2 HIGH
if(value == 0) {
// execute this code if the switch widget is now OFF
digitalWrite(ledPin,LOW); // Set digital pin 2 LOW
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
pinMode (ledPin,OUTPUT);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// Check other examples on how to communicate with Blynk. Remember to avoid delay() function!
@SergiHH Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Pete, is possible to delete all and start again the QuickStart Template and the QuickStart Device? I mean, ask if Blynk can create again the QuickStart Template and Device.
I could make my project working fine building it again. Now I have it installed on my whater heater, like I had with old Blynk.
Now I’m going to export to new Blynk my other project working with old blynk too: reading the electricity consumptions in my home… wish me luck!
Thank you very much.
Sergi
