Hi
Without the deep sleep code the program works great, as soon as I try the deep sleep version I do not get any data from the DHT22. The ESP32 goes to sleep & wakes up fine. Please advise
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you'll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#define BLYNK_TEMPLATE_ID "TMPLDpJzlkfM"
#define BLYNK_DEVICE_NAME "ESP32"
#define BLYNK_AUTH_TOKEN "_0B2R4U-N-q9u44azYzL6dJbm6EKZzFm";
#define uS_TO_S_FACTOR 100000
#define TIME_TO_SLEEP 300
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <DHT.h>
#include <DHT_U.h>
char ssid[] = "";
char pass[] = "";
#define DHTPIN 4 // What digital pin we're connected to
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)){
return;
Blynk.virtualWrite(V6, h);
Blynk.virtualWrite(V5, t);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
dht.begin();
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
Serial.println("Setup ESP32 to sleep for every " + String(TIME_TO_SLEEP) + " Seconds");
Serial.println("Going to sleep now");
delay(100);
Serial.flush();
esp_deep_sleep_start();
Serial.println("This message will never be printed");
Thank you Pete for your prompt reply
I think I did as you suggested but sadly still information on the dashboard.
It will be an achievement when it is working for sure.
the Blynk App.
WARNING :
https://github.com/adafruit/DHT-sensor-/';
App project setup:
#include <WiFi.h>
#include <DHT.h>
#include <DHT_U.h>
char ssid[] = "";
char pass[] = "";
void sendSensor()
if (isnan(h) || isnan(t)) {
return;
dht.begin();
BLYNK_CONNECTED() {
sendSensor();
delay(100);
Serial.flush();
I would place the dht.begin() before the blynk.begin(…).
I am not sure how the “BLYNK_CONNECTED” is called, technically. As a callback from blynk.begin or some kind of interrupt. (I probably should know, but I dont…)
Anyway, placing the dht.begin before, ensures it is executed fully before the SendSensor (which include reading the sensor) is executed. To avoid risking you are trying to read an unitialized sensor.
(This might be unnecessary. I am not sure, but placing before would be safer. In my opinion.)
Another thing may be that you are reading to soon after initialising. I dont remember, but the DHT sensor might need a short time to pass after init until first stable reading can be done. (I could be wrong.) But if you experience “unstable” readings you could try a “delay (1000)” after the dht.begin and before blynk.begin.
As said, I am not sure, but could be a simple thing to test.
Blynk.connected is a callback from the Blynk library, which I think is triggered when Blynk.run is executed and the status has changed from disconnected to connected.
I think some serial prints would be very handy to help diagnose what’s happening.
