Hi all,
i try to read values from a virtual PIN into my Node-Red using the “node-red-contrib-blynk-ws (1.0.5)”.
I use the “wss://192.168.1.2:9443/websocket” adress. The PIN show’s up as connect but no data appears.
I have tried different virtual PINs same result.
But i can see that in the Admin GUI some messages for WebSocket get counted if i add it to node-red.
Blynk libary: 0.6.1
Local Server: 0.41.15 (installed in Docker)
Do anybody has a similar problem ? Or any Idea how to read out the Data or further debugging ?
Best,
Patrick
