Don’t have access to the custom chart on the Plus plan as the docs suggest. Either update docs or might be a bug relating to permissions on the widget. Here’s an excerpt from the console docs:
Hello, Widget Documentation Under Update Now
Thanks can you then confirm that the Custom Chart will not be available on the PLUS plan?
Yes confirm. Will not be available for PLUS
