Butter
                    November 15, 2018,  6:50pm
              1
              Hi, I’m making a project with esp8266 nodemcu, but when I upload the code Arduino throws this warning:
WARNING: library NewPing claims to run on (avr, arm) architecture(s) and may be incompatible with your current board which runs on (esp8266) architecture(s).
I looked for NewPing library compatible with esp8266, but didnt find anything. Any advice?
              forget NewPing lib, it is useless!
let us show your sketch
                Butter
                    November 15, 2018,  7:57pm
              3
              Here it is. What can I use instead of NewPing?
#include <NewPing.h>
    #define SONAR_NUM 1
    #define PI 3.1415926535897932384626433832795
    //** CHANGE TO SUIT TANK DIMENSIONS
    const int MAX_DISTANCE = 15;
    const int Diameter = 4;
    const int Depth = 13;
    const unsigned int Period = 2000;
    //** SENSOR PINS
    const int TrigPin = 5;          //     GPIO5,  D1
    const int EchoPin = 4;          //     GPIO4,  D2
    const int Area = PI * ((Diameter / 2) * (Diameter / 2));
    // Global variables
    int Liters,Distance,DepthWater;
    char ssid[] = "IFBA-wifi";
    char pass[] = "******";
   char auth[] = "***************";
    NewPing sonar[SONAR_NUM] = {
	    NewPing(TrigPin, EchoPin, MAX_DISTANCE)
void sendSensorReadings()
//***********Readings Tank 1
    Distance = sonar[0].ping_cm();
    if (Distance >= Depth || Distance == 0 )  Distance =Depth;
	DepthWater = Depth - Distance;
	Liters = (Area * DepthWater) / 1000;
//***********SEND INFO TO BLYNK
    Blynk.virtualWrite(V1, DepthWater);
    Blynk.virtualWrite(V2, Liters);
    Blynk.virtualWrite(V3, Liters / 10);
    delay(50);
    digitalWrite(13, HIGH);
    delay(50);
    digitalWrite(13, LOW);
//************************* can be commented out, test use only
    Serial.println();
    Serial.println();
    Serial.println("Tank Distance: " + String(Distancia));
    Serial.println("Tank DepthWater: " + String(DepthWater));
    Serial.println("Tank Liters: " + String(Liters));
    pinMode(13, OUTPUT); //LED D7
	timer.setInterval(Period, sendSensorReadings);
//**    can be commented out, test only
    Serial.println();
    Serial.println("Connecting to " + String(ssid));
	delay(20);
              delete newping
this is the code to get distance from sensor
  digitalWrite(TRIGGER, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIGGER, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(ECHO, HIGH);
  distance = ((duration / 2) / 29.1) * 10;
                Gunner
                    November 15, 2018,  9:59pm
              5
              And here is an example i made for the Ultrasonic sensor… As I already posted in your other topic .
    #16 - Ultrasonic Distance Sensor with Servo
This little project used the HC-SR04 Ultrasonic sensor… but instead of boring old distance numbers, it will also position a servo within a range of selected distances.
This sketch demonstrates a timer that can be enabled and disabled, so as not to be running something like the Ultrasonic sensor if other critical timing functions need to run.
And also demonstrates enabling and disabling the servo, so that there is no jitter or fluttering when it is n…
