So im really looking forward to Blynking, but I cannot seem to get my arduino Uno to connect to the App on my iphone Using serial USB. I upload this code and all that comes out in serial monitor is my auth token. When I open the app all I have is a button connected to digital Pin 6, I press the play button and It says “Arduino UNO is Offline.” Im no C professional and I know Im doing something wrong. Any suggestions? Have a great night or day, wherever you are
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* This example shows how to use ordinary Arduino Serial
* to connect your project to Blynk.
* Feel free to apply it to any other example. It's simple!
* 1. Optional, but recommended.
* Connect additional USB-serial adapter to see the prints.
* 2. Edit auth token and upload this sketch.
* 3. Run the script (script located in "scripts" folder of library root,
* e.g. 'blynk-library/scripts') for redirecting traffic to server:
* for Windows:
* 1. Open cmd.exe
* 2. write : (your way to blynk-ser.bat folder) example: "cd C:\blynk-library-0.3.1\blynk-library-0.3.1\scripts"
* 3. write : "blynk-ser.bat -c COM4" (where COM4 is port with your Arduino)
* 4. And press "Enter" , press "Enter" and press "Enter"
* for Linux and OSX:
* ./blynk-ser.sh (may need to run with sudo)
* You can specify port, baud rate, and server endpoint like this:
* ./blynk-ser.sh -c <serial port> -b <baud rate> -s <server address> -p <server port>
* For instance :
* ./blynk-ser.sh -c /dev/ttyACM0 -b 9600 -s cloud.blynk.cc -p 8442
* Run blynk-ser.sh -h for more information
* Be sure to select the right serial port (there may be multiple).
* Attention!
* Arduino IDE may complain with "programmer is not responding".
* You need to terminate script before uploading new sketch.
* 4. Start blynking! :)
SoftwareSerial SwSerial(0, 1); // RX, TX
#define BLYNK_PRINT SwSerial
#include <BlynkSimpleSerial.h>
char auth[] = "a345226523e146a682c75d5fa17b602f";
SwSerial.begin(9600);
Blynk.begin(auth);
// Default baud rate is 9600. You could specify it like this:
//Blynk.begin(auth, 57600);
