I’m just running tests with Blynk - I have bluetooth working and can switch LEDs on and off etc
The next step was to read a voltage on GPIO 2 -
The problem I’ve got is that the result of the code below is always 4095 output. It seems that the analogue read always returns 4095
If I comment out the lines Blynk.begin and Blynk.run I get the output I expect.
I obviously don’t understand something - I need the anaolgue pin value in my code for control later but when Blynk is running I don’t appear to be able to get any value other than 4095
#include <BlynkSimpleEsp32_BT.h>
char auth[] = "........riqfV";
WidgetLCD lcd(V1);
const int TPin = 2;
int TempReading = 0;
Blynk.setDeviceName("HotTub");
Blynk.begin(auth);
TempReading = analogRead(TPin);
Serial.println(TempReading);
delay(500);
