what is mean of this section?
#when true - allows reading worker to trigger hardware even app is offline
allow.reading.widget.without.active.app=false
why we need to install
sudo apt-get install fail2ban
on Local Server(cause i have some problem on installing it).
This when you want to Introduction - Blynk Documentation to work without app online.
You don’t need it. But this is additional security tool.
pi@raspberrypi:~ $ sudo apt-add-repository ppa:webupd8team/java
sudo: apt-add-repository: command not found
add-apt-repository
sudo apt-get install software-properties-common python-software-properties
sudo add-apt-repository ppa:webupd8team/java
are the below Link updated?
https://github.com/blynkkk/blynk-server
What do you mean?
i mean new configuration and docs about install server with new part and details are updated?
Yes. As far as I know.
