HARDWARE: ESP32-WROOM32
DEVICE: ANDROID 14
BYLNK SERVER REGION: NY3
BLYNK LIBRARY VERSION: 1.3.2?
I’m currently working on a project where I’m using an ESP32 to control two XL9535-K16V5 16ch relay boards via I2C, with control toggled between the boards using a virtual switch (V16) in the Blynk app.
Overview
(Controlling 32 relays w/ 16 buttons)
I’ve got 16 buttons (V0-V15) to control the first 16 relays on the first I2C relay board and I have a switch (V16 - Value 0 when off & Value 1 when on) and when the switch is turned on, the same 16 buttons will then control the 16 relays on the second I2C board.
- Setup: I have two XL9535 boards at addresses 0x20 and 0x21. I’m using Blynk to control 16 relays (V0-V15) on these boards.
- Control Logic: When V16 is OFF (0), buttons control relays on the first board (0x20). When V16 is ON (1), they control the second board (0x21).
Issue:
Despite the switch state changing correctly in the Blynk app and being reflected in the serial monitor, the buttons always control the first board (0x20), regardless of V16’s state.
Here’s what I’ve tried:
Direct Pin Reading: I’ve modified my code to directly read V16’s state each time a button press is processed.
Debugging Output: Added serial prints to confirm V16’s state and which board should be controlled.
Delay in Loop: Added a small delay in the loop to ensure state changes are recognized.
Code:
#define BLYNK_TEMPLATE_ID "TMPL XXXXX"
#define BLYNK_TEMPLATE_NAME "XXXXX"
#define BLYNK_AUTH_TOKEN "XXXXX"
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
#include <Wire.h>
// Your Wi-Fi credentials
char ssid[] = "XXXX";
char pass[] = "XXXX";
#define I2C_SDA 21
#define I2C_SCL 22
// Addresses of the two XL9535-K16V5 boards
#define XL9535_ADDR1 0x20 // First board address
#define XL9535_ADDR2 0x21 // Second board address
// Function to initialize I2C and set up the XL9535 boards
void setupXL9535() {
Wire.begin(I2C_SDA, I2C_SCL);
// Initialize both boards
Wire.beginTransmission(XL9535_ADDR1);
Wire.write(0x00); // Mode register
Wire.write(0x00); // All outputs off
Wire.endTransmission();
Wire.beginTransmission(XL9535_ADDR2);
// Function to control relays
void controlRelay(byte addr, byte relay, bool state) {
Wire.beginTransmission(addr);
byte data = Wire.read();
if (state) {
data |= (1 << relay); // Turn on the relay
data &= ~(1 << relay); // Turn off the relay
Wire.write(data);
// Function to handle button presses
void handleButtonPress(int pin, int state) {
int relayIndex = pin - V0;
int board = digitalRead(V16) ? XL9535_ADDR2 : XL9535_ADDR1;
controlRelay(board, relayIndex, state);
Serial.print("Button ");
Serial.print(pin);
Serial.print(" changed state to ");
Serial.print(state);
Serial.print(" controlling relay ");
Serial.print(relayIndex + 1);
Serial.print(" on board ");
Serial.println(board == XL9535_ADDR2 ? "2" : "1");
// Setup Blynk for each button
void setupBlynkButtons() {
for (int i = V0; i <= V15; i++) {
Blynk.virtualWrite(i, LOW); // Initialize all buttons to off state
BLYNK_WRITE(V16) {
int pinValue = param.asInt();
Serial.print("Switch state changed to: ");
Serial.println(pinValue);
// Small delay to ensure the state change is recognized
delay(100);
// Define BLYNK_WRITE for each button (V0-V15)
BLYNK_WRITE(V0) {
int state = param.asInt();
handleButtonPress(V0, state);
BLYNK_WRITE(V1) {
handleButtonPress(V1, state);
BLYNK_WRITE(V2) {
handleButtonPress(V2, state);
BLYNK_WRITE(V3) {
handleButtonPress(V3, state);
BLYNK_WRITE(V4) {
handleButtonPress(V4, state);
BLYNK_WRITE(V5) {
handleButtonPress(V5, state);
BLYNK_WRITE(V6) {
handleButtonPress(V6, state);
BLYNK_WRITE(V7) {
handleButtonPress(V7, state);
BLYNK_WRITE(V8) {
handleButtonPress(V8, state);
BLYNK_WRITE(V9) {
handleButtonPress(V9, state);
BLYNK_WRITE(V10) {
handleButtonPress(V10, state);
BLYNK_WRITE(V11) {
handleButtonPress(V11, state);
BLYNK_WRITE(V12) {
handleButtonPress(V12, state);
BLYNK_WRITE(V13) {
handleButtonPress(V13, state);
BLYNK_WRITE(V14) {
handleButtonPress(V14, state);
BLYNK_WRITE(V15) {
handleButtonPress(V15, state);
setupXL9535();
setupBlynkButtons();
delay(100); // Small delay to ensure state changes are recognized
Serial Monitor Output:
Switch state changed to: 0
Button 0 changed state to 15 controlling relay 1 on board 1
Switch state changed to: 1
Button 0 changed state to 0 controlling relay 1 on board 1
