🟢 New Device Connection Status Setting!
Using The Things Stack, Blues, or AWS IoT Core with Blynk? Or sending data via HTTP(S)? Devices that periodically send data but don’t maintain a constant connection can now be marked as online when data is received as expected.
:small_blue_diamond: What’s new?
With the “Log when device reports any data” setting, your device will stay online for a set period after sending data, even if it doesn’t maintain a continuous connection.
:small_blue_diamond: Who needs to enable this?
• If you’re using Blynk’s integrations with TTS, Blues, or AWS IoT Core, be sure to turn this setting ON so Blynk relies on the last reported data instead of a login event to determine if the device is online.
• Using HTTP(S)? If your device sends data but doesn’t keep a connection to the Blynk server, this update is for you!
:link: Try it now and keep your device tracking more accurate than ever!
Cheers!
The Blynk Team
