I want to create a timer to turn the device on and off on the ESP
I’m trying to use automation but it doesn’t seem to work as I want
Any ideas? Thanks
Difficult to provide any constructive advice without knowing more.
I’m not sure that automation can create timers similar to Blynk Legacy.
I’m still confused with the features in automation
I have generated timer event on a virtual pin and it turned on 1 when time came but when it went off it didn’t have any state change to 0
That button appears when you have set the datastream to a switch (in automations) and made it available to actions.
The position of that button represents what the automation should do at the pre-set time. As your button is in the OFF position, it means that at 3:34pm Mon-Fri the Timer datastream will be turned OFF by the automation.
