Arduino: 1.8.12 (Windows 10), Board: “ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None”
libraries\IRremote\esp32.cpp.o:(.bss.timer+0x0): multiple definition of `timer’
sketch\Edgent_ESP32_ir_trial.ino.cpp.o:(.bss.timer+0x0): first defined here
c:/users/jamsa/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/…/lib/gcc/xtensa-esp32-elf/5.2.0/…/…/…/…/xtensa-esp32-elf/bin/ld.exe: Warning: size of symbol `timer’ changed from 580 in sketch\Edgent_ESP32_ir_trial.ino.cpp.o to 4 in libraries\IRremote\esp32.cpp.o
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for “WiFi.h”
Used: C:\Users\jamsa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WiFi
Not used: C:\Users\jamsa\OneDrive\Documents\Arduino\libraries\WiFiNINA
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
Multiple libraries were found for “IRremote.h”
Used: C:\Users\jamsa\OneDrive\Documents\Arduino\libraries\IRremote
Not used: C:\Users\jamsa\OneDrive\Documents\Arduino\libraries\Arduino-IRremote-master
Multiple libraries were found for “BlynkSimpleEsp32_SSL.h”
Used: C:\Users\jamsa\OneDrive\Documents\Arduino\libraries\Blynk
Not used: C:\Users\jamsa\OneDrive\Documents\Arduino\libraries\blynk-library-master
Not used: C:\Program Files (x86)\Arduino\libraries\Blynk
exit status 1
Error compiling for board ESP32 Dev Module.
“Show verbose output during compilation”
option enabled in File → Preferences.
Anyone can tell us why? this happn
