Probably the easiest way is via editing profile on server: @Dmitriy could you advice?
Mmmmm…looks like timer input widget has been affected with this update.
What do you think @Dmitriy and @BlynkAndroidDev?
Wow, yep, that’s a bug, - today later I’ll upload one more build with small fixes (like no paddings on some of your buttons) and will fix this issue too.
What device are you using? I could not reproduce this text crop on mine ones.
Samsung S7 edge
Wow, what’s the previous setup was? Ou, I’ve just started to investigate why text size on tabs has been so large on your 1440x2560 device, and it was some display scaling setup?
And what font size is selected in your Number Input widget?
I had my display settings fully zoomed. It’s strange because when I moved the zoom slider back to half way all the blynk widgets increased in size. It better now.
The largest…its now set to mid size. Still happy.
It looks like we were calculating text size for Time Input (it doesn’t support mentioned in this release font size unification) like for a large display, but because of the scale it became too large, that strange that before it was ok - the only changes in this widget were a slight adjustment of paddings.
Large font size in Number Input is for 2x or larger height - so it could look better when it is large.
I’ve settled for mid size…apologies for thinking it was a blynk issue.
@BlynkAndroidDev, I can’t see the 2.26.0 in Play store only the 2.25.1. Currently I’m on test build. Is the 2.26.0 an incremental build, so I do need to update to 2.25.1 first?
Maybe, it is not available on all google play servers at now moment
Yes, It just appeared…
Quick comparison between ‘test build’ and the new 2.26.0.:
Overall GOOD, but why again fonts got a bit smaller???
That test build had not checked font’s paddings, that’s why it had a bit larger font, but for some languages it would be cropped.
For gauge and ordinary button - we will add font size option to them.
Terminal using Device tile and Selector is freezed/forced quit on my mobile… I’using local server and had the newest (38.0) updates…
Cant rename report widget
