New Android Release 1.15.0
What’s new :
  1. Added new widget Table.
  2. Fixed daylight saving issue for RTC and TimeInput (You need to remove and add widget to make it work);
  3. Music Player widget now can change state via setProperty.
@Dmitriy 2. Remove and add back just TimeInput widget or also RTC, or just RTC?
@Costas both. Just to be sure.
@Dmitriy please confirm the Blynk cloud server has all the updates.
Confirming :). Servers are up to date.
@Dmitriy
Dear Dmitriy, do we have to update the arduino blynk library as well? I have/use 0.3.8 and I can not find newer release…
Thanks!
@mikekgr no. 0.3.8 should be fine. new library release is not yet ready, however it will be released soon too.
Any news on the bouncing ball issue when resuming the app?
I still have that issue (also with new release). I open the app, it connects perfectly. I put it in background and open it later and the bouncing balls go on and on. When I close the app and open again it reconnects almost immediately.
Hello. Are you able yo ping our server?
You nay try local server. If issue still exists this is 100% wiring/hardware problem. You can also try to downgrade library and check if that helps. Creating separate topic, adding your sketch and wiring also may help :).
Currently I have no local server, and not changing any sketch or wiring since it works yesterday…
Ok I will create new topics on this …
Best regards & thanks
Is issue still reproducible right now?
When can we expect iOS release for tables?
I’ve try to compile the example AdvancedTimeInput.ino but i give this error: “‘TimeInputParam’ was not declared in this scope” maybe I must wait the new library?
Yes. Or you can take latest directly from gtihub repo.
