I try to control a Neopixel-Ring (24 LEDs) with blynk app. I managed to control the Neopixel-Ring via php but I have now idea how to do this via blynk. Any suggestions?
Cheers
cbmainz
Cheers
cbmainz
whatβs the problem?
This is my code I tried to port from my php control, but I have no clue on how to do this with blynk:
#include "application.h"
#include "neopixel/neopixel.h"
#include "blynk/blynk.h"
SYSTEM_MODE(AUTOMATIC);
/* ======================= extra-examples.cpp ======================== */
// IMPORTANT: Set pixel COUNT, PIN and TYPE
#define PIXEL_COUNT 24
#define PIXEL_PIN D6
#define PIXEL_TYPE WS2812B
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
char auth[] = "xxx";
Blynk.begin(auth);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
Blynk.virtualWrite(21)
int color = param[0].asInt();
for(int i=0; i< strip.numPixels(); i++)
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + color) & 255));
strip.show();
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
Please check how to use Virtual Pins: http://docs.blynk.cc/#blynk-main-operations-send-data-from-app-to-hardware
you need to rewrite your code
Burt how to tell blynk wich hardware pin to use?
you can put any (your own) code inside BLYNK_WRITE, including cotrolling NeoPixel
ha, now it works.
BLYNK_WRITE(V1)
int shift = param.asInt();
for (int i = 0; i < strip.numPixels(); i++)
strip.setPixelColor(i, Wheel(shift & 255));
// OR: strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + shift) & 255));
strip.show();
Easy, right?
