NeoPixel Trouble using Wifi and ESP8266
The project is already working quite well so far.When I try to switch to rpot_valuebowCycle, the LEDs are turned on and animated but I lose the connection to the app and can’t switch anymore.
#include <Adafruit_NeoPixel.h>
#include <EEPROM.h>
#include <DHT.h>
#define PIN D1
#define NUM_LEDS 118
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
WidgetLED led1(V0); //register to virtual pin 2
float h;
float t;
byte R = 255;
byte G = 255;
byte B = 255;
int BRIGHTNESS = 255;
int RANDOM;
byte INX=0;
DHT dht(4,DHT11);
    Blynk.begin("OCtYCIL54atnovxblgGIZwJ67InlSqAM", "FRITZ!Box 7530 CL", "36077145894523948219");
    strip.begin();
    dht.begin();
    timer.setInterval(100L, RGBData); //timer will run every sec
BLYNK_WRITE(V2) //Button Widget is writing to pin
    RANDOM = param.asInt();
BLYNK_WRITE(V1)
    if (RANDOM == 0){
      R = param[0].asInt();
      G = param[1].asInt();
      B = param[2].asInt();
BLYNK_WRITE(V3) //Button Widget is writing to pin
    BRIGHTNESS = param.asInt();
BLYNK_READ(V5)
    int h = dht.readHumidity();
    Blynk.virtualWrite(V5,h);
BLYNK_READ(V6)
    int t = dht.readTemperature();
    Blynk.virtualWrite(V6,t);
BLYNK_WRITE(V4) {
    Blynk.syncAll();
    INX = param.asInt();
    EEPROM.put(0, INX);
void RGBData(){
  if(RANDOM == 1)
    R = random(0,255);
    G = random(0,255);
    B = random(0,255);
  strip.setBrightness(BRIGHTNESS); //Brightness of LEDs
  EEPROM.get(0,INX);
  switch(INX){
    case 1 : {
                // LED off
                led1.off();
                RGBoff;
                break;
    case 2  : {
                // RGBLoop - no parameters
                led1.on();
                RGBLoop();
                break;
    case 3  : {
                // FadeInOut - Color (red, green. blue)
                led1.on();
                FadeInOut(R, G, B); // red
                break;
    case 4  : {
                // Strobe - Color (red, green, blue), number of flashes, flash speed, end pause
                led1.on();
                Strobe(R, G, B, 10, 50, 1000);
                break;
    case 5  : {
                // CylonBounce - Color (red, green, blue), eye size, speed delay, end pause
                led1.on();
                CylonBounce(R, G, B, 4, 10, 50);
                break;
    case 6  : {
                // Twinkle - Color (red, green, blue), count, speed delay, only one twinkle (true/false)
                led1.on();
                Twinkle(R, G, B, 10, 100, false);
                break;
    case 7  : {
                // TwinkleRandom - twinkle count, speed delay, only one (true/false)
                led1.on();
                TwinkleRandom(20, 100, false);
                break;
    case 8  : {
                // Sparkle - Color (red, green, blue), speed delay
                led1.on();
                Sparkle(R, G, B, 0);
                break;
    case 9 : {
                // Running Lights - Color (red, green, blue), wave dealy
                led1.on();
                RunningLights(R,G,B, 50);
                break;
    case 10 : {
                // colorWipe - Color (red, green, blue), speed delay
                led1.on();
                colorWipe(R,G,B, 50);
                break;
    case 11 : {
                // rpot_valuebowCycle - speed delay
                led1.on();
                rpot_valuebowCycle(50);
                break;
    case 12 : {
                // fire
                led1.on();
                Fire(55,120,15);
                break;
    case 13 : {
                // meteorRain
                led1.on();
                meteorRain(R,G,B,10, 55, true, 30);
                break;
    case 14 : {
                // LED off
                led1.off();
                RGBoff;
                break;
// ** LEDEffect Functions **
void RGBoff(){
  setAll(0,0,0);
  showStrip();
void Fire(int Cooling, int Sparking, int SpeedDelay) {
  static byte heat[NUM_LEDS];
  int cooldown;
  // Step 1.  Cool down every cell a little
  for( int i = 0; i < NUM_LEDS; i++) {
    cooldown = random(0, ((Cooling * 10) / NUM_LEDS) + 2);
    if(cooldown>heat[i]) {
      heat[i]=0;
      heat[i]=heat[i]-cooldown;
  // Step 2.  Heat from each cell drifts 'up' and diffuses a little
  for( int k= NUM_LEDS - 1; k >= 2; k--) {
    heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2]) / 3;
  // Step 3.  Randomly ignite new 'sparks' near the bottom
  if( random(255) < Sparking ) {
    int y = random(7);
    heat[y] = heat[y] + random(160,255);
    //heat[y] = random(160,255);
  // Step 4.  Convert heat to LED colors
  for( int j = 0; j < NUM_LEDS; j++) {
    setPixelHeatColor(j, heat[j] );
  showStrip();
  delay(SpeedDelay);
void setPixelHeatColor (int Pixel, byte temperature) {
  // Scale 'heat' down from 0-255 to 0-191
  byte t192 = round((temperature/255.0)*191);
  // calculate ramp up from
  byte heatramp = t192 & 0x3F; // 0..63
  heatramp <<= 2; // scale up to 0..252
  // figure out which third of the spectrum we're in:
  if( t192 > 0x80) {                     // hottest
    setPixel(Pixel, 255, 255, heatramp);
  } else if( t192 > 0x40 ) {             // middle
    setPixel(Pixel, 255, heatramp, 0);
  } else {                               // coolest
    setPixel(Pixel, heatramp, 0, 0);
void meteorRain(byte red, byte green, byte blue, byte meteorSize, byte meteorTrailDecay, boolean meteorRandomDecay, int SpeedDelay) {
  setAll(0,0,0);
  for(int i = 0; i < NUM_LEDS+NUM_LEDS; i++) {
    // fade brightness all LEDs one step
    for(int j=0; j<NUM_LEDS; j++) {
      if( (!meteorRandomDecay) || (random(10)>5) ) {
        fadeToBlack(j, meteorTrailDecay );
    // draw meteor
    for(int j = 0; j < meteorSize; j++) {
      if( ( i-j <NUM_LEDS) && (i-j>=0) ) {
        setPixel(i-j, red, green, blue);
    showStrip();
    delay(SpeedDelay);
void fadeToBlack(int ledNo, byte fadeValue) {
 #ifdef ADAFRUIT_NEOPIXEL_H
    // NeoPixel
    uint32_t oldColor;
    uint8_t r, g, b;
    int value;
    oldColor = strip.getPixelColor(ledNo);
    r = (oldColor & 0x00ff0000UL) >> 16;
    g = (oldColor & 0x0000ff00UL) >> 8;
    b = (oldColor & 0x000000ffUL);
    r=(r<=10)? 0 : (int) r-(r*fadeValue/256);
    g=(g<=10)? 0 : (int) g-(g*fadeValue/256);
    b=(b<=10)? 0 : (int) b-(b*fadeValue/256);
    strip.setPixelColor(ledNo, r,g,b);
 #endif
 #ifndef ADAFRUIT_NEOPIXEL_H
   // FastLED
   leds[ledNo].fadeToBlackBy( fadeValue );
 #endif
void RGBLoop(){
  for(int j = 0; j < 3; j++ ) {
    // Fade IN
    for(int k = 0; k < 256; k++) {
      switch(j) {
        case 0: setAll(k,0,0); break;
        case 1: setAll(0,k,0); break;
        case 2: setAll(0,0,k); break;
      showStrip();
      delay(3);
    // Fade OUT
    for(int k = 255; k >= 0; k--) {
      switch(j) {
      showStrip();
      delay(3);
void FadeInOut(byte red, byte green, byte blue){
  float r, g, b;
  for(int k = 0; k < 256; k=k+1) {
    r = (k/256.0)*red;
    g = (k/256.0)*green;
    b = (k/256.0)*blue;
    setAll(r,g,b);
    showStrip();
  for(int k = 255; k >= 0; k=k-2) {
    r = (k/256.0)*red;
    b = (k/256.0)*blue;
    setAll(r,g,b);
    showStrip();
void Strobe(byte red, byte green, byte blue, int StrobeCount, int FlashDelay, int EndPause){
  for(int j = 0; j < StrobeCount; j++) {
    setAll(red,green,blue);
    showStrip();
    delay(FlashDelay);
    setAll(0,0,0);
    showStrip();
    delay(FlashDelay);
 delay(EndPause);
void CylonBounce(byte red, byte green, byte blue, int EyeSize, int SpeedDelay, int ReturnDelay){
  for(int i = 0; i < NUM_LEDS-EyeSize-2; i++) {
    setAll(0,0,0);
    setPixel(i, red/10, green/10, blue/10);
    for(int j = 1; j <= EyeSize; j++) {
      setPixel(i+j, red, green, blue);
    setPixel(i+EyeSize+1, red/10, green/10, blue/10);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
  for(int i = NUM_LEDS-EyeSize-2; i > 0; i--) {
    setAll(0,0,0);
    showStrip();
    delay(SpeedDelay);
  delay(ReturnDelay);
void Twinkle(byte red, byte green, byte blue, int Count, int SpeedDelay, boolean OnlyOne) {
  setAll(0,0,0);
  for (int i=0; i<Count; i++) {
     setPixel(random(NUM_LEDS),red,green,blue);
     showStrip();
     delay(SpeedDelay);
     if(OnlyOne) {
       setAll(0,0,0);
  delay(SpeedDelay);
void TwinkleRandom(int Count, int SpeedDelay, boolean OnlyOne) {
  setAll(0,0,0);
     setPixel(random(NUM_LEDS),random(0,255),random(0,255),random(0,255));
     showStrip();
     delay(SpeedDelay);
     if(OnlyOne) {
       setAll(0,0,0);
  delay(SpeedDelay);
void Sparkle(byte red, byte green, byte blue, int SpeedDelay) {
  int Pixel = random(NUM_LEDS);
  setPixel(Pixel,red,green,blue);
  showStrip();
  delay(SpeedDelay);
  setPixel(Pixel,0,0,0);
void SnowSparkle(byte red, byte green, byte blue, int SparkleDelay, int SpeedDelay) {
  setPixel(Pixel,0xff,0xff,0xff);
  showStrip();
  delay(SparkleDelay);
  showStrip();
  delay(SpeedDelay);
void RunningLights(byte red, byte green, byte blue, int WaveDelay) {
  int Position=0;
  for(int i=0; i<NUM_LEDS*2; i++)
      Position++; // = 0; //Position + Rate;
      for(int i=0; i<NUM_LEDS; i++) {
        // sine wave, 3 offset waves make a rpot_valuebow!
        //float level = sin(i+Position) * 127 + 128;
        //setPixel(i,level,0,0);
        setPixel(i,((sin(i+Position) * 127 + 128)/255)*red,
                   ((sin(i+Position) * 127 + 128)/255)*green,
                   ((sin(i+Position) * 127 + 128)/255)*blue);
      showStrip();
      delay(WaveDelay);
void colorWipe(byte red, byte green, byte blue, int SpeedDelay) {
  for(uint16_t i=0; i<NUM_LEDS; i++) {
      setPixel(i, red, green, blue);
      showStrip();
      delay(SpeedDelay);
void rpot_valuebowCycle(int SpeedDelay) {
  byte *c;
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< NUM_LEDS; i++) {
      c=Wheel(((i * 256 / NUM_LEDS) + j) & 255);
      setPixel(i, *c, *(c+1), *(c+2));
    showStrip();
    delay(SpeedDelay);
byte * Wheel(byte WheelPos) {
  static byte c[3];
  if(WheelPos < 85) {
   c[0]=WheelPos * 3;
   c[1]=255 - WheelPos * 3;
   c[2]=0;
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   c[0]=255 - WheelPos * 3;
   c[1]=0;
   c[2]=WheelPos * 3;
   WheelPos -= 170;
   c[0]=0;
   c[1]=WheelPos * 3;
   c[2]=255 - WheelPos * 3;
  return c;
// ** FastLed/NeoPixel Common Functions **
// Apply LED color changes
void showStrip() {
   // NeoPixel
   strip.show();
 #endif
   // FastLED
   FastLED.show();
 #endif
// Set a LED color (not yet visible)
void setPixel(int Pixel, byte red, byte green, byte blue) {
   // NeoPixel
   strip.setPixelColor(Pixel, strip.Color(red, green, blue));
 #endif
   // FastLED
   leds[Pixel].r = red;
   leds[Pixel].g = green;
   leds[Pixel].b = blue;
 #endif
// Set all LEDs to a given color and apply it (visible)
void setAll(byte red, byte green, byte blue) {
  for(int i = 0; i < NUM_LEDS; i++ ) {
  showStrip();
Reading this topic may help you to understand the issue, and potential solutions…
