Hi I am currently teaching a class on electronics and have run into an obstacle. I have created a program for my Arduino uno to control a DIY scoreboard we made using 60 neopixles. The problem is we are currently using the BLE101 app and the UI is ugly and not user friendly. I was wondering if anyone could help give me some tips on how to convert this code over to Blynk Bluetooth. Would help me and my class out greatly. Below is the code we are using.
#include <CurieBLE.h>
#include <Adafruit_NeoPixel.h>
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 3
#define NUMPIXELS 60
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_RGB + NEO_KHZ800);
int delayVal = 5000;
uint32_t colorList[] = { pixels.Color(0,0,255), pixels.Color(255,255,255) };// blue , white
BLEPeripheral blePeripheral; // BLE Peripheral Device (the board you're programming)
BLEService arduinoService("6fbee06f-b902-4ac1-bf99-8d4a9b76db8f"); // create service
// create switch characteristic and allow remote device to read and write
BLECharCharacteristic pinD6Char("DD06", BLERead | BLEWrite );
BLECharCharacteristic pinD7Char("DD07", BLERead | BLEWrite );
BLECharCharacteristic pinD8Char("DD08", BLERead | BLEWrite );
BLECharCharacteristic pinD9Char("DD09", BLERead | BLEWrite );
BLECharCharacteristic pinD10Char("DD10", BLERead | BLEWrite );
BLECharCharacteristic pinD11Char("DD11", BLERead | BLEWrite );
BLECharCharacteristic myDchars[6] = {pinD6Char,pinD7Char,pinD8Char,pinD9Char,pinD10Char,pinD11Char};
int score[2] = {0,0};
long previousMillis = 0; // last time the battery level was checked, in ms
int oldDValues[4] = {0,0,0,0}; // previous values for each digital pin
const int pinD6 = 6;
const int pinD7 = 7;
const int pinD8 = 8;
const int pinD9 = 9;
const int pinD10 = 10;
const int pinD11 = 11;
int myDPins[6] = {pinD6, pinD7, pinD8, pinD9, pinD10, pinD11};
const int characterOffset = 15;
charLayout[0] = [1,1,1,
1,0,1,
1,0,1,
1,0,1,
1,1,1];
int charLayout[10][15] = {
{1,1,1,1,0,1,1,0,1,1,0,1,1,1,1}, //0
{1,1,0,0,1,0,0,1,0,0,1,0,1,1,1}, //1
{1,1,1,1,0,0,1,1,1,0,0,1,1,1,1}, //2
{1,1,1,1,0,0,1,1,1,1,0,0,1,1,1}, //3
{1,0,1,1,0,1,1,1,1,1,0,0,0,0,1}, //4
{1,1,1,0,0,1,1,1,1,1,0,0,1,1,1}, //5
{1,1,1,0,0,1,1,1,1,1,0,1,1,1,1}, //6
{1,1,1,1,0,0,0,0,1,1,0,0,0,0,1}, //7
{1,1,1,1,0,1,1,1,1,1,0,1,1,1,1}, //8
{1,1,1,1,0,1,1,1,1,1,0,0,0,0,1} //9
Serial.begin(9600); // initialize serial communication
pixels.begin(); // This initializes the NeoPixel library.
for (int i=0; i < 6; i++){
pinMode(myDPins[i], OUTPUT);
digitalWrite(myDPins[i], LOW);
/* Set a local name for the BLE device
This name will appear in advertising packets
and can be used by remote devices to identify this BLE device
The name can be changed but maybe be truncated based on space left in advertisement packet */
blePeripheral.setLocalName("BLE101"); // must use this name for the BLE101 app to find it.
blePeripheral.setAdvertisedServiceUuid(arduinoService.uuid()); // add the service UUID
blePeripheral.addAttribute(arduinoService); // Add the BLE Battery service
// Configure digital ports
for (int i=0; i < 6; i++) {
blePeripheral.addAttribute(myDchars[i]);
myDchars[i].setValue(0);
myDchars[0].setEventHandler(BLEWritten, listener0);
myDchars[1].setEventHandler(BLEWritten, listener1);
myDchars[2].setEventHandler(BLEWritten, listener2);
myDchars[3].setEventHandler(BLEWritten, listener3);
myDchars[4].setEventHandler(BLEWritten, listener4);
myDchars[5].setEventHandler(BLEWritten, listener5);
/* Now activate the BLE device. It will start continuously transmitting BLE
advertising packets and will be visible to remote BLE central devices
until it receives a new connection */
blePeripheral.begin();
Serial.println("Bluetooth device active, waiting for connections...");
setNumber(0,00);
setNumber(1,00);
BLECentral central = blePeripheral.central();
// if a central is connected to peripheral:
if (central) {
//blePeripheral.poll();
Serial.print("Connected to central: ");
// print the central's MAC address:
Serial.println(central.address());
// turn on the LED to indicate the connection:
digitalWrite(13, HIGH);
// check the battery level every 200ms
// as long as the central is still connected:
while (central.connected()) {
long currentMillis = millis();
// if 200ms have passed, check the battery level:
if (currentMillis - previousMillis >= 200) {
// when the central disconnects, turn off the LED:
digitalWrite(13, LOW);
Serial.print("Disconnected from central: ");
void setNumber(int side, int displayNum) {
int sideOffset = side*characterOffset*2;
int ones = (displayNum%10);
int tens = ((displayNum/10)%10);
for(int k=0;k<15;k++){
toggleLocation(side, k+sideOffset, charLayout[tens][k]);
toggleLocation(side, k+characterOffset+sideOffset, charLayout[ones][k]);
pixels.show();
//delay(delayVal);
void toggleLocation(int side, int loc, int ledState){
Serial.println(loc);
if(ledState==0){
pixels.setPixelColor(loc, pixels.Color(0,0,0)); //off
} else{
pixels.setPixelColor(loc, colorList[side]); // team color
void sendDigitalValue(int pinNum) {
if (digitalRead(myDPins[pinNum]) == LOW) {
char lowValue = LOW;
myDchars[pinNum].setValue(lowValue);
char highValue = HIGH;
myDchars[pinNum].setValue(highValue);
bool haschangedDigital(int pinNum) {
char currentValue = digitalRead(myDPins[pinNum]);
char previousValue = oldDValues[pinNum];
if (currentValue != previousValue) {
oldDValues[pinNum] = currentValue;
return true;
return false;
void listener0(BLECentral& central, BLECharacteristic& characteristic) {
setScore(0,-1);
void listener1(BLECentral& central, BLECharacteristic& characteristic) {
setScore(0,0);
void listener2(BLECentral& central, BLECharacteristic& characteristic) {
setScore(0,1);
void listener3(BLECentral& central, BLECharacteristic& characteristic) {
setScore(1,-1);
void listener4(BLECentral& central, BLECharacteristic& characteristic) {
setScore(1,0);
void listener5(BLECentral& central, BLECharacteristic& characteristic) {
setScore(1,1);
void setScore(int team, int val){
int teamScore = score[team];
if(val==0){
teamScore=0;
teamScore += val;
if (teamScore<0){
teamScore=0;
score[team]=teamScore;
setNumber(team,teamScore);
Serial.print("Team 1: ");
Serial.print(score[0]);
Serial.print(" - Team 2: ");
Serial.print(score[1]);
Serial.println("");
