I would like to know if someone could help me with my project, which consists of using a mega arduino, max6675, through blynk, but I can not think of how to put it together:grin:
Only instead of just displaying to the IDE monitor, you can also send it to your App, say a display widget or something using Blynk.virtualWrite(vPin, data)
Check out the Documents and Getting Started links at the Top Right of this page.
Thank you for being a great help
How could you send the temperature data to blynk
#include <Ethernet.h>
#include "max6675.h"
int thermoDO = 4;
int thermoCS = 5;
int thermoCLK = 6;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
int vccPin = 3;
int gndPin = 2;
char auth[] = "e818933df44e420cb05f21bbefa933d4";
#define W5100_CS 10
#define SDCARD_CS 4
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
// You can also specify server.
// For more options, see Boards_Ethernet/Arduino_Ethernet_Manual example
//Blynk.begin(auth, "your_server.com", 8442);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8888);
// use Arduino pins
pinMode(vccPin, OUTPUT); digitalWrite(vccPin, HIGH);
pinMode(gndPin, OUTPUT); digitalWrite(gndPin, LOW);
Serial.println("MAX6675 test");
// wait for MAX chip to stabilize
delay(500);
// basic readout test, just print the current temp
Blynk.virtualWrite(v6, data)
Serial.print("C = ");
Serial.println(thermocouple.readCelsius());
Serial.print("F = ");
Serial.println(thermocouple.readFahrenheit());
You need to read up about this information in the documentation and guide links I already posted above. Donāt just copy and paste the command I gave, as it needs specific parameters such as:
Blynk.virtualWrite(V6, thermocouple.readCelsius()) // V6 is a Labeled Display on V6 with /pin/ Ā°C in the label
Blynk.virtualWrite(V7, thermocouple.readFahrenheit()) // V7 is a Labeled Display on V7 with /pin/ Ā°F in the label
You also donāt want to run these commands in the void loop()
as they will send too much data too quickly to the app and cause āfloodingā: http://docs.blynk.cc/#troubleshooting-flood-error
Look up SimpleTimer in the search option and there are also many examples using timers in the Sketch Builder - Top Right of this page.
Check out this one and add in the above commands into the timer loop: http://examples.blynk.cc/?board=Arduino%20Mega%202560&shield=Ethernet%20Shield%20W5100&example=GettingStarted%2FPushData
