Need Help with my coding
My coding is about watering plant. For the sensors (DHT11, ph sensor and soil moisture), I connect to the arduino. For the relay (which is connect to water pump), I connect to the nodemcu. All of the sensor and relays are function well but the problem is, my blynk does not show notification even when it meet the requirement.
Details about hardware:
  1. Arduino ESP8266 CH-340 V2 NodeMCU Lua Wifi Controller Board.
  2. Arduino Compactible DCCduino Uno R3.
  3. Phone : Android 10
This is the Arduino Code :
#include <EEPROM.h>
#include <Wire.h>
#include <dht.h>
#define SensorPinPH A0
#define Offset 0.00
#define samplingInterval 20
#define printInterval 800
#define ArrayLength  40
int pHArray[ArrayLength];
int pHArrayIndex=0;
LiquidCrystal_I2C lcd(0x27, 16, 2);
SoftwareSerial ArduinoUno (3, 2);
float i, j, k, m;
#define SensorPin A1
#define dht_apin A2
dht DHT;
float sensorValue = 0;
   ArduinoUno.begin(4800);
   pinMode(A0, INPUT);
   pinMode(A1, INPUT);
   pinMode(A2, INPUT);
   lcd.begin();
           static unsigned long samplingTime = millis();
           static unsigned long printTime = millis();
           static float pHValue,voltage;
           if(millis()-samplingTime > samplingInterval)
                pHArray[pHArrayIndex++]=analogRead(SensorPinPH);
                if(pHArrayIndex==ArrayLength)pHArrayIndex=0;
                voltage = avergearray(pHArray, ArrayLength)*5.0/1024;
                pHValue = 3.5*voltage+Offset;
                samplingTime=millis();
          if(millis() - printTime > printInterval)   //Every 800 milliseconds, print a numerical, convert the state of the LED indicator
                Serial.print("Voltage:");
                Serial.print(voltage,2);
                Serial.print("    pH value: ");
                Serial.println(pHValue,2);
                printTime=millis();
        DHT.read11(dht_apin);
        sensorValue = analogRead(SensorPin);
        delay(500);
        i = sensorValue;
        int i1 = i + 2000;
        ArduinoUno.print(i1);
        ArduinoUno.println("\n");
        Serial.println(i1,2);
        j = DHT.humidity;
        int j1 = j + 4000;
        ArduinoUno.print(j1);
        Serial.println(j1,2);
        k = DHT.temperature;
        int k1 = k + 6000;
        ArduinoUno.print(k1);
        Serial.println(k1,2);
        m = pHValue;
        int m1 = m + 8000;
        ArduinoUno.print(m1);
        Serial.println(m1,2);
        delay(30);
double avergearray(int* arr, int number){
  int i;
  int max,min;
  double avg;
  long amount=0;
  if(number<=0){
    Serial.println("Error number for the array to avraging!/n");
    return 0;
  if(number<5){   //less than 5, calculated directly statistics
    for(i=0;i<number;i++){
      amount+=arr[i];
    avg = amount/number;
    return avg;
  }else{
    if(arr[0]<arr[1]){
      min = arr[0];max=arr[1];
    else{
      min=arr[1];max=arr[0];
    for(i=2;i<number;i++){
      if(arr[i]<min){
        amount+=min;        //arr<min
        min=arr[i];
      }else {
        if(arr[i]>max){
          amount+=max;    //arr>max
          max=arr[i];
        }else{
          amount+=arr[i]; //min<=arr<=max
      }//if
    }//for
    avg = (double)amount/(number-2);
  }//if
  return avg;
This is the NodeMCU code:
const int PumpMotor = D3;
// ================= CONNECT TO WIFI ================
char auth[] = "***************";
char ssid[] = "****************";
char pass[] = "**************";
float rpm;
int a, b;
SoftwareSerial NodeMCU(D2, D1);
void kecepatan () {
  while (NodeMCU.available() > 0) {
    rpm = NodeMCU.parseFloat();
    if (NodeMCU.read() == '\n') {
      if (rpm >= 2000 && rpm <= 3023){
      int rpm1 = rpm;
      int rpm2 = rpm1 - 2000;
      Blynk.virtualWrite(V1,rpm2);
      if (rpm2 >=1000){
      digitalWrite(PumpMotor,LOW);
      delay(2000);
      digitalWrite(PumpMotor,HIGH);
      Serial.println("Too Dry, water already plant automatically!");
      Blynk.notify("Too Dry");
      if (rpm >= 4000 && rpm <= 5023){
      int rpm3 = rpm;
      int rpm4 = rpm3 - 4000;
      Blynk.virtualWrite(V2,rpm4);
      if (rpm >= 6000 && rpm <= 7023){
      int rpm5 = rpm;
      int rpm6 = rpm5 - 6000;
      Blynk.virtualWrite(V3,rpm6);
      if (rpm6 >= 38){
      Blynk.notify("Temperature too hot, Press WATER button if you want water your plant");
      if (rpm >= 8000 && rpm <= 9023){
      int rpm7 = rpm;
      int rpm8 = rpm7 - 8000;
      Blynk.virtualWrite(V4,rpm8);
      if (rpm8 <= 5){
      Blynk.notify("Water Too Acidic, Please Change Your Water");
      if (rpm8 >= 8){
      Blynk.notify("Water Too Alkaline, Please Change Your Water");
BLYNK_WRITE(V5)
  b = param.asInt();
  if (b==HIGH){
    delay (3000);
  else{
  NodeMCU.begin(4800);
  pinMode(D2, INPUT);
  pinMode(D1, OUTPUT);
  pinMode(PumpMotor, OUTPUT);
  timer.setInterval(400L, kecepatan);
I am very new to Arduino and Blynk. I hope someone can help me to get the notification from Blynk. Thank you in advanced.
You omitted some important information…
  1. Add details :
    • Blynk Library version
I’ve also deleted your duplicate topic. Please don’t do this!
Im really sorry @PeteKnight, my problem already solved, but can I ask something new question.
When the new blynk 2.0 app (1.1.2) release, is it effect the old version of the blynk app? Because right now I am using old version of blynk (2.27.29) instead of new version and before this, the old version of Blynk app can read data from nodemcu, but now it cannot, I hope you can help me
Everything is different with the new version of Blynk.
Different cloud servers, different app, slightly different C++ library, and the web dashboard where most of the configuration of templates, datastreams etc is done.
The code used on the devices (NodeMCU for example) will be roughly the same, but the libraries will be different and some of the commands will be different too.
