Help !!! Help your brother, I used blynk app with nodemcu (esp8266), integrating it with ifttt & webhooks too. The blink buttons I created are perfectly working with action on the nodemcu. The Google Assistant is working too, but NO ACTION on the nodemcu.
I login into ifttt with Google account (PC)also used in Google Assistant. & Later SWITCHED to MY MOBILE PHONE TO SIGN IN as you had instructed me.
@Leejin please don’t tag posts like this on onto the end of unrelated topics. I’ve moved your post to a new topic this time, but in future your post will simply be deleted.
Father, thanks so much for your paramount concern. I’m new here, so I never understand the rules, but I’ve understood you very well now. I’m using blynk legacy and my blynk buttons are working perfectly, I’m only having issue with the integration[google assistant] [webhooks failure]. In the first place , when my Blynk APP wasn’t connecting,so I followed the previous advice you gave to a blynk member…[ uninstall the blynk, reboot and reinstall] , I really appreciate for that, FATHER.
won’t work (even when your auth token is replaced with his) because the IFTTT servers could be anywhere in the world, and will most likely resolve to the wrong cloud server and give an ‘invalid auth token’ error (which you don’t see in IFTTT). This is because the Blynk cloud servers don’t do re-direction on API calls.
First step in the diagnostic process is to work-out if the person is using Blynk Legacy or Blynk IoT.
The second step is to find which Blynk cloud server their project resides on, and ensure that its IP address is being used in the IFTTT URL.
It was a mistake, it’s been awhile since the last time I used IFTTT so I forgot to tell him to replace the blynk-cloud.com with his blynk cloud IP, I modified the post.
