hi and hello,so this is my first time codding.im currently do a final year project.so my problem is i cant control the stepper motor.my idea is to control the stepper motor right and left using the widget button.
the servo is working fine.in this project iām using arduino uno,nema 17 stepper motor & cnc shield.i hope someone can help me and sorry for my bad english. thank you
#define BLYNK_PRINT SwSerial
#include <AccelStepper.h>
#include <Servo.h>
Servo servo;
char auth[] = "xqsVPKNYmAiaiAtUe01Cto5Du3RSiWGb";
#define enablePin 8
AccelStepper Xaxis(1, 2, 5); // pin 2 = step, pin 5 = direction
const byte servoPin = 11; // limit z
byte pos = 0;
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
servo.attach(servoPin);
pinMode(enablePin, OUTPUT);
BLYNK_WRITE(V1){
int rightBtn = param.asInt();
if(rightBtn == 1) { // if Button sends 1
right(); // start the function
void right(){
digitalWrite(enablePin, LOW);
Xaxis.setMaxSpeed(1000.0);
Xaxis.setAcceleration(500.0);
Xaxis.moveTo(1000);
BLYNK_WRITE(V2){
int leftBtn = param.asInt();
if(leftBtn == 1) { // if Button sends 1
left(); // start the function
void left(){
Xaxis.moveTo(-1000);
BLYNK_WRITE(V5){
servo.write(0);
BLYNK_WRITE(V6){
servo.write(90);
