I have used Blynk timer in a simple way and i know how to use timer.setTimout and set.timeInterval etc. But in this project i am a little stuck.
This is an Wemos D1 Mini that controlls an SSR relay that allows me to turn on/off my fan heater in the basement via button in the app etc.
All works fine, but i need to set a timer that turns off the relay (fan heater) automaticly after lets say 4 hours. I have tried timer.disable and timer.reset in several ways and i know i,m doing something wrong here, but kan someone give me an example out of the code posted below on how i can do this in simpliest way please?
Also, when i push the app button to turn on heater, i want the heater to turn off after 4 hours. If i turn off the heater via app and turn it on again i want the timer to start over.
note that SSR_timeout_timer_ID needs to be declared as a global integer variable so that you can use it to disable the timer from anywhere in your sketch.
Can you please give me an example for where the code snippets will place in code please? I,m not quite shure…
When i start the relay and turn on the heater, i get the timer to stop after 10 seconds. But when i turn off the heater via app after 5 seconds and turn it on again the timer is not reset. It stays on for 5 seconds and turns off.
I want the timer to reset when i turn of the heater via app and start over again when i turn it on.
I have an heater connected to the solid state relay that i can turn on/off via button in app. When i turn on the heater with the app button, i want the timer to start. (lets say 10 seconds for now when we test).
BUT… when i turn of the heater in blynk app button BEFORE the time (10 seconds) has gone, i want the timer to reset, and start over when i turn on the heater again via blynk app button.
Okay, I thi9nk this is working, but you’ll need to test it thoroughly…
#include <OneWire.h>
#define ONE_WIRE_BUS 14
int relayPin = 15;
int onLED = 12;
int buttonState;
int SSR_on_duration = 10 * 1000; // 10 seconds - for testing
int SSR_timeout_timer_ID;
char auth[] = "REDACTED";
char ssid[] = "REDACTED";
char pass[] = "REDACTED";
Serial.begin(74880);
pinMode(relayPin, OUTPUT);
pinMode(onLED, OUTPUT);
timer.setTimeout(10L, [](){}); // Sacrificial timer to overcome SimpleTimer bug
timer.setInterval(1000L, temp);
BLYNK_CONNECTED()
Blynk.syncVirtual(V1); // Changed from syncAll, as only the V1 widget seems to need to be synched
void emergencyOFF()
turn_off_SSR();
Blynk.virtualWrite(V3, "SJEKK TEMPERATUR!!");
Blynk.notify("SJEKK TEMPERATUR!");
void temp()
Serial.print("Temperatur: ");
Serial.println(sensors.getTempCByIndex(0));
Blynk.virtualWrite(V2, sensors.getTempCByIndex(0));
Blynk.virtualWrite(V5, sensors.getTempCByIndex(0));
if (sensors.getTempCByIndex(0) > 60)
emergencyOFF();
Blynk.virtualWrite(V3, " ");
void turn_off_SSR()
timer.disable(SSR_timeout_timer_ID); // stop the timeout timer if it's not yet completed
digitalWrite(relayPin, LOW);
Blynk.virtualWrite(V1, LOW);
digitalWrite(onLED, LOW);
Serial.println("SSR Off");
BLYNK_WRITE(V1)
buttonState = param.asInt();
if (buttonState == 1) {
digitalWrite(relayPin, HIGH);
digitalWrite(onLED, HIGH);
Serial.println("SSR On");
SSR_timeout_timer_ID = timer.setTimeout(SSR_on_duration, turn_off_SSR); // Start the timeout timer
turn_off_SSR();
Changes I’ve made/things to be aware of…
Added a sacrificial timer in slot 0 to overcome the SimpleTimer bug
You don’t declare the timeout timers in void setup, only when/where you need them.
Added a parameter of SSR_on_duration to define how long the relay stays on for (set to 10 seconds)
Added more functionality to the turn_off_SSR function and removed it from elsewhere, to reduce code repetition
Changed the baud rate to 74880 as I was testing on a NodeMCU and this is the default baud rate, so it allows me to see boot messages from the board as well as serial output without having to switch baud rates in the serial monitor.
