Hello Blynkers
i need some help with my code . basicely im trying to add my home made arduino (sender)to arduino ethernet (receiver) and from there save it on history graph.
Here’s where i got my sample code https://www.arduino.cc/en/Tutorial/MasterReader
here's modified code that i need help with// Wire Master Reader
// by Nicholas Zambetti <http://www.zambetti.com>
// Demonstrates use of the Wire library
// Reads data from an I2C/TWI slave device
// Refer to the "Wire Slave Sender" example for use with this
// Created 29 March 2006
// This example code is in the public domain.
#include <OneWire.h>
#include <Wire.h>
// Data wire is plugged into pin 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
// Pass our oneWire reference to Dallas Temperature.
void setup(void)
Wire.begin(8); // join i2c bus with address #8
Wire.onRequest(requestEvent); // register event
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
// Start up the library
sensors.begin(); // IC Default 9 bit. If you have troubles consider upping it 12. Ups the delay giving the IC more time to process the temperature measurement
void loop(void)
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
Serial.print("Temperature for Device 1 is: ");
Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"? You can have more than one IC on the same bus. 0 refers to the first IC on the wire
}void requestEvent() {
float floatTempC = sensors.getTempCByIndex(0);
char t_buffer[15];
dtostrf(floatTempC, 8, 9, t_buffer);//i think something is wrong here
Wire.write(t_buffer);// respond with message of 6 bytes
// as expected by master
and here is receiver code
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
Wire.requestFrom(8, 6); // request 6 bytes from slave device #8
while (Wire.available()) { // slave may send less than requested
char c = Wire.read(); // receive a byte as character
Serial.print(c); // print the character
delay(500);
any help would be greatly appreciated
Thanx
