this is my code, i have been tried to do runRelay under 1 second so the motor can be stop on right position, there is a delay when limit swith touched
void setup(){
timer.setInterval(500L, runRelay);
timer.setInterval(1000L,sendSensor);
void loop(){
void runRelay(){
kanopi();
checkAutomation();
//this is limit switch function
void kanopi() {
openK = digitalRead(kanopiOpen_pin);
closedK = digitalRead(kanopiClose_Pin);
delay(250);
// Serial.println((String)"Limit Buka = "+openK);
// Serial.println((String)"Limit Tutup = "+closedK);
if (openK == 1 && closedK == 0) {
checkKanopi("kanopi_tertutup", 1);
} else if (openK == 0 && closedK == 1) {
checkKanopi("kanopi_terbuka", 0);
} else if (openK == 1 && closedK == 1) {
if(staterelayOffManual == 1){
checkKanopi("kanopi_berhenti", 4);
}else{checkKanopi("bergerak", 2);}
} else{
checkKanopi("kanopi_error", 3);
void checkKanopi(const String& event, int data_log){
// Serial.println("---------------------------------------------");
// Serial.println("Kanopi " + event);
log_kanopi = data_log;
Blynk.virtualWrite(V4, data_log);
Blynk.logEvent(event);
BLYNK_WRITE(V12){
pinvalueOtomatis = param.asInt();
void checkAutomation(){
if(pinvalueOtomatis == 1){
controlrelayAuto();
Blynk.setProperty(V11, "isHidden", true);
staterelayOffManual = 0;
}else{
Blynk.setProperty(V11, "isHidden", false);
kanopiManual();
void relay() {
Serial.println("Logika Motor : " + String(log_motor) + " Logika Kanopi : " + String(log_kanopi));
void operateRelayBlynk(const String& statusRelay, int setpinOpen, int setpinClose, int blynkValue, int virtualPin) {
digitalWrite(relayOpen_pin, setpinOpen);
digitalWrite(relayClose_pin, setpinClose);
Blynk.virtualWrite(virtualPin, blynkValue);
// Serial.println("Kanopi" + statusRelay);
// Serial.println("Jalan Auto");
void controlrelayAuto(){
// logic_kanopi();
if (log_motor == 0 && log_kanopi == 1) {//Opening
operateRelayBlynk("Bergerak Membuka",HIGH, LOW, 1, V2);
} else if (log_motor == 1 && log_kanopi == 0) {//Closing
operateRelayBlynk("Bergerak Menutup",LOW, HIGH, 1, V2);
} else if (log_motor == 0 && log_kanopi == 0) {//Openend
operateRelayBlynk("Sudah Terbuka",LOW, LOW, 0, V2);
} else if (log_motor == 1 && log_kanopi == 1) {//Closed
operateRelayBlynk("Sudah Tertutup",LOW, LOW, 0, V2);
void controlrelayOpen(int kanopi){
if (kanopi == 1) {
}else if (kanopi == 0) {
operateRelayBlynk("Sudah Terbuka", LOW, LOW, 0, V2);
}else if (log_kanopi == 2){
// Serial.println("Jalan Manual");
void controlrelayClose(int kanopi){
if (kanopi == 1) {
operateRelayBlynk("Sudah Tertutup", LOW, LOW, 0, V2);
operateRelayBlynk("Bergerak Menutup", LOW, HIGH, 1, V2);
void controlrelayOff(){
operateRelayBlynk("Berhenti ",LOW, LOW, 0, V2);
