i use nodemcu ,dht11 sensor ,i2c lcd
i want to display temperature and humidity on lcd
how to modify code ?
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include <EEPROM.h>
#include <DHT.h>
char auth[] = "4ecda56a656542f0825bb1704b711c4b";
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
EEPROM.begin(512);
WiFiManager wifiManager;
//wifiManager.resetSettings(); //Uncomment this to wipe WiFi settings from EEPROM on boot. Comment out and recompile/upload after 1 boot cycle.
wifiManager.autoConnect("NodeMCU");
Serial.println("connected...yeey :)");
pinMode(BUILTIN_LED, OUTPUT); // Initialize the BUILTIN_LED pin as an output, I like blinkies.
Blynk.begin(auth, WiFi.SSID().c_str(), WiFi.psk().c_str(), "cyrax.top", 8080);
dht.begin();
Blynk.run(); // Commented out for a short time.
