Need help on GPS STREAM
I need help with my project using GPS stream.
My project is to set a relay contact during a second when i arrive near my home location to automaticaly open my gate .
i use ESP8266 with wifi connection my phone is a oneplus 6 .
It doesn’t work , the location send by my phone GPS seem no to be update .
this is my sketch code .
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  App project setup:
    GPS Stream widget on V1.
char auth[] = "****************";
char ssid[] = "************";
char pass[] = "*************";
// definition variables
float homeLat = xxxxxxxxxxx;
float homeLon = xxxxxxxxxxxxxxxx;
float thresholdDistance =100; // meter
BLYNK_WRITE(V1)
  GpsParam gps(param);
  float distance=0;
  float distance2=0;
  long x=0;
  long y=0;
  digitalWrite(0, HIGH);
surveille:
   x=0; //init x
do
      distance = distanceCalc(homeLat, homeLon, gps.getLat(), gps.getLon());
      Blynk.virtualWrite(V6,x);
      Blynk.virtualWrite(V5,distance);
      x=x+1;
      delay(1500);
    } while(distance>thresholdDistance);
   digitalWrite(0, LOW);   // mets à 1a sortie
   delay(1000);               // Attendre 1 seconde - Wait for a second
   digitalWrite(0,HIGH);    // Mets la sortie à 0
   y=0; //init y
  do
      distance2 = distanceCalc(homeLat, homeLon, gps.getLat(), gps.getLon());
      Blynk.virtualWrite(V8,distance2);
      Blynk.virtualWrite(V7,y );
      y=y+1;
      delay(1500);
    } while(distance2<thresholdDistance);
    goto surveille;
float distanceCalc(float lat1, float long1, float lat2, float long2)
  float distLat, distLong, distance;
  distLat = (lat1 - lat2) * 111194.9;
  distLong = 111194.9 * (long1 - long2) * cos(radians((lat1 + lat2) / 2));
  distance = sqrt(pow(distLat, 2) + pow(distLong, 2));
  return distance; // in meter
  pinMode(0, OUTPUT);     // Initialise la broche 0 comme une sortie
I’ve taken a quick look at your code and the do…while…goto loop seems to be the problem. Your code is going around this loop and not getting any new values from the GPS stream widget.
Also, the delays in those loops, and the fact that your code isn’t being allowed to return to the void loop and process the Blynk.run command, mean that your device will most likely disconnect from the Blynk server after around 10 seconds.
Thanks @PeteKnight,
I try this code , what do you think about it ?
BLYNK_WRITE(V1)
void Affiche_Distance()
if(distance > thresholdDistance)
      Flag=0;
        if( Flag==0)
          Flag=1;
  Blynk.virtualWrite(V6,Flag);
  timer.setInterval(1000L,Affiche_Distance);
It looks better, but does it work?
Thank you @PeteKnight for your advise.
It’s works now !!!
Benj
