BLYNK
BLYNK.IO       📲 GETTING STARTED       đź“— DOCS       👉 SKETCH BUILDER
Need help on data extract to csv
I`ve pruchased to blynk Plus already, however there is no option for me to extract data from my superchat, i can only enlarge the chart.
a
Hardware : Nodemcu 8266 , Mpu6050 sensor
smartphone : iphone13
code :
#include <Wire.h>               // Only needed for Arduino 1.6.5 and earlier
#include "SH1106Wire.h"   // legacy: #include "SH1106.h"
#include <Adafruit_Sensor.h>
#define BLYNK_TEMPLATE_ID "TMPLiNiVSQCx"
#define BLYNK_DEVICE_NAME "Quickstart Template"
#define BLYNK_AUTH_TOKEN "dyyPrXguxjcgsuJixlTNUrcZQaCOfoyS"
#include <Blynk.h>
SH1106Wire display(0x3c, SDA, SCL);     // ADDRESS, SDA, SCL
//Adafruit_MPU6050 mpu;
const int MPU_addr=0x68;
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
int minVal=265;
int maxVal=402;
double x;
double y;
double z;
char ssid[] = "ESP8266BLYNK";                       // Your WiFi credentials.
char pass[] = "MPU6050T";
 Wire.begin();
 Wire.beginTransmission(MPU_addr);
 Wire.write(0x6B);
 Wire.write(0);
 Wire.endTransmission(true);
 Serial.println();
 Serial.println();
 // Initialising the UI will init the display too.
 display.init();
 display.flipScreenVertically();
 display.setFont(ArialMT_Plain_10);
 delay(500);
 Wire.write(0x3B);
 Wire.endTransmission(false);
 Wire.requestFrom(MPU_addr,14,true);
 AcX=Wire.read()<<8|Wire.read();
 AcY=Wire.read()<<8|Wire.read();
 AcZ=Wire.read()<<8|Wire.read();
 int xAng = map(AcX,minVal,maxVal,-90,90);
 int yAng = map(AcY,minVal,maxVal,-90,90);
 int zAng = map(AcZ,minVal,maxVal,-90,90);
 x= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI);
 y= RAD_TO_DEG * (atan2(-xAng, -zAng)+PI);
 z= RAD_TO_DEG * (atan2(-yAng, -xAng)+PI);
 Serial.print("AngleX= ");
 Serial.println(x);
 Serial.print("AngleY= ");
 Serial.println(y);
 Serial.print("AngleZ= ");
 Serial.println(z);
 Serial.println("-----------------------------------------");
 // clear the display
 display.clear();
 display.setTextAlignment(TEXT_ALIGN_LEFT);
 String buf;
 buf = "X: " + String(x);
 display.setFont(ArialMT_Plain_16);
 display.drawString(0, 0,buf);
 buf = "Y: " + String(y);
 display.drawString(0, 16,buf);
 buf = "Z: " + String(z);
 display.drawString(0, 32,buf);
 display.display();
 Blynk.virtualWrite(V0, x);
 Blynk.virtualWrite(V1, y);
 Blynk.virtualWrite(V2, z);
Please edit your post and add triple backticks ( ``` ) before and after your whole sketch.
whole sketch? sorry I don’t get it bro
Like this
triple backticks
done, thank you , hopefully you can help me
Check this out
https://docs.blynk.io/en/blynk.console/devices/actions-with-devices#download-report
b
I don’t have the advance setting option in my superchart in Blynk App
If i download through the web, the report i obtain is just this (picture attached above), I need the readings from my 3 Virtual pins
Look at the way that you’ve configured the datastreams in the Template screen.
In the Advanced section, is “Show in Reports” turned on?
Good day sir, i can`t any such option , could you pls guide me further ?
Post a screenshot of one of your datastream configurations, with the Advanced section expanded.
i cant find this option in my mobile app, this is a screenshot from the web
It’s not available in the mobile app, it’s done via the web console Templates > Datastreams > Edit > Advanced.
The option was turned on
