I am a new born Blynker and i just do not understand something. I found out how to use the button ( simpley put it to a digital pin 3 to 10 on a uno inside the App). But i want to see it also whit the LED inside the blynk app when it is realy on. Feedback from the digital poort. Can any body help me whit a solution. I am just starting to lurn this soo keep it simple pleas. Thanks Frank
Hai Yes and al other examples. The problem is that you do not do any programming when i am using the button in the app. But some time the app stop or has a delay.I want to check if the digital output on the arduino is high or low But i simply do not find that answer. think as a loop back in this way. Frank
Hai
as a beginner i understand part of your code. Do i not need to declayer the ( inpin)?
or should i place the digital D6 in there? if so how is the digital D6 called in c++
i have the WidgetLED led6(6); line put in whit succes
relay 0 has button D6 and LED V6
relay 1 has button D7 and LED V7
relay 2 has Button D8 and LED V8
ect…
If i tab on button D7 the digital has a High o then arduino and the relay switsches. I would like that the LED V7 is than on and isoff when the relay button is also off. I
Sorry if my questions look stupit but we all have too lurn (=;
