Need help getting feedback status of external switching
@Dmytro no such link is opening from Github…:frowning: . Facing problem to check status. I am using a two way switch and a relay(i.e. controlled by blynk). When blynk switch is on and physical switch is off, then light is off but blynk switch remains on, that makes a problem.Please reply As soon as possible.
  code:/**************************************************************
 * This example runs directly on ESP8266 chip.
 * Note: This requires ESP8266 support package:
 *   https://github.com/esp8266/Arduino
 * Please be sure to select the right ESP8266 module
 * in the Tools -> Board menu!
 * Change WiFi ssid, pass, and Blynk auth token to run :)
char pass[] = "YourPassword";
@subhajitm01 You were asking for assistance on a post almost a year old… things change in weeks let alone that long :wink:
I have moved your issue into it’s own topic and formatted your code properly for viewing… please use this method in the future.
As for current examples, we now have the Sketch Builder, link is at the top right of this page.
http://examples.blynk.cc/?board=ESP8266&shield=ESP8266%20WiFi&example=More%2FSync%2FButtonInterrupt
http://examples.blynk.cc/?board=ESP8266&shield=ESP8266%20WiFi&example=More%2FSync%2FButtonPoll
Umm… after looking closer at your sketch… there is nothing there? How are you controlling this relay… direct pin manipulation in the App? If so, then you are not going to have an easy way of getting feedback without code and perhaps additional sensors.
Redundant topic, user had also created another.
