Need Help for my Arduino IDE
Hello, Good day everyone! Can someone help me with this issue regarding on my Arduino IDE something is wrong I think. The codes works but then when I compile again there seem to be a problem.
CODE:
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_TEMPLATE_NAME ""
#define BLYNK_AUTH_TOKEN ""
#include <ESP8266_Lib.h>
#include <Wire.h>
#include <DS3231.h>
#include <EEPROM.h>
#include "GravityTDS.h"
#include "DHT.h"
#include <EEPROM.h>
char ssid[] = "";
char pass[] = "";
const unsigned long TIME_CHECK_BLYNK_CONNECTION = 60000;  // (ms) check device connection to blynk every this time
//pH normal range
const float NORMAL_RANGE_PH_MIN = 5.5; // minimum pH for normal
const float NORMAL_RANGE_PH_MAX = 7.5; // maximum pH for normal
This is what happen after compiling.
C:\Users\admin\AppData\Local\arduino\sketches\3F6475FDF187DB2301F8BC0A8F38F6CE\libraries\BlynkESP8266-master\ESP8266.cpp.o (symbol from plugin): In function `ESP8266::ESP8266(Stream*)':
(.text+0x0): multiple definition of `ESP8266::ESP8266(Stream*)'
C:\Users\admin\AppData\Local\arduino\sketches\3F6475FDF187DB2301F8BC0A8F38F6CE\sketch\ESP8266.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `ESP8266::checkIPD(String&)'
(.text+0x0): multiple definition of `ESP8266::rx_empty()'
(.text+0x0): multiple definition of `ESP8266::run()'
(.text+0x0): multiple definition of `ESP8266::recvString(String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::recvString(String, String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::recvString(String, String, String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::eATCWAUTOCONN(unsigned char)'
(.text+0x0): multiple definition of `ESP8266::setAutoConnect(unsigned char)'
(.text+0x0): multiple definition of `ESP8266::qATCIPSTAMAC(String&, unsigned char)'
(.text+0x0): multiple definition of `ESP8266::getStationMac(unsigned char)'
(.text+0x0): multiple definition of `ESP8266::eATCIPSTAMAC(String, unsigned char)'
(.text+0x0): multiple definition of `ESP8266::setStationMac(String, unsigned char)'
(.text+0x0): multiple definition of `ESP8266::qATCIPSTAIP(String&, unsigned char)'
(.text+0x0): multiple definition of `ESP8266::getStationIp(unsigned char)'
(.text+0x0): multiple definition of `ESP8266::eATCIPSTAIP(String, String, String, unsigned char)'
(.text+0x0): multiple definition of `ESP8266::setStationIp(String, String, String, unsigned char)'
(.text+0x0): multiple definition of `ESP8266::qATCIPAP(String&, unsigned char)'
(.text+0x0): multiple definition of `ESP8266::getAPIp(unsigned char)'
(.text+0x0): multiple definition of `ESP8266::eATCIPAP(String, unsigned char)'
(.text+0x0): multiple definition of `ESP8266::setAPIp(String, unsigned char)'
(.text+0x0): multiple definition of `ESP8266::eCWSTARTSMART(unsigned char)'
(.text+0x0): multiple definition of `ESP8266::startSmartConfig(unsigned char)'
(.text+0x0): multiple definition of `ESP8266::eCWSTOPSMART()'
(.text+0x0): multiple definition of `ESP8266::stopSmartConfig()'
(.text+0x0): multiple definition of `ESP8266::eATCIPSTATUS(String&)'
(.text+0x0): multiple definition of `ESP8266::getIPStatus()'
(.text+0x0): multiple definition of `ESP8266::sATCIPSTARTSingle(String, String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::createTCP(String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::registerUDP(String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::sATCIPSTARTMultiple(unsigned char, String, String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::createTCP(unsigned char, String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::registerUDP(unsigned char, String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::sATCIPSENDSingle(unsigned char const*, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::send(unsigned char const*, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::sATCIPSENDMultiple(unsigned char, unsigned char const*, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::send(unsigned char, unsigned char const*, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::sATCIPSENDSingleFromFlash(unsigned char const*, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::startTCPServer(unsigned long)'
(.text+0x0): multiple definition of `ESP8266::startServer(unsigned long)'
(.text+0x0): multiple definition of `ESP8266::stopTCPServer()'
(.text+0x0): multiple definition of `ESP8266::stopServer()'
(.text+0x0): multiple definition of `ESP8266::sATCIPMODE(unsigned char)'
(.text+0x0): multiple definition of `ESP8266::setCIPMODE(unsigned char)'
(.text+0x0): multiple definition of `ESP8266::eATSAVETRANSLINK(unsigned char, String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::saveTransLink(unsigned char, String, unsigned long)'
(.text+0x0): multiple definition of `ESP8266::eATPING(String)'
(.text+0x0): multiple definition of `ESP8266::setPing(String)'
(.text+0x0): multiple definition of `ESP8266::sATCIPSTO(unsigned long)'
(.text+0x0): multiple definition of `ESP8266::setTCPServerTimeout(unsigned long)'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
@b1nned Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your compiler error message so that it displays correctly.
Also, the compiler error message means nothing without the associated code that you were compiling at the time.
Use triple backticks when posing your code too.
You’ve posted an incomplete sketch. It has no void setup or void loop, so I assume that you’ve truncated your sketch somehow.
