Need help: ESP-01 (Blynk) + UNO (normal sketch)
hello all,
i have project :
ESP-01 = Running Blynk Sketch and as Commands Sender to control Arduino pin through RX TX
UNO = Running normal sketch (without Blynk) proccessing command from SoftwareSerial from ESP-01
everything is goes normal and i can control (send command) my UNO, the problem is :
ESP-01 can send Serial.print () or Serial.write () and,UNO can take it as command and process it but
How can i get data value from Input (sensor or button) from my UNO and send it to ESP-01?
i have tried to send the value from UNO using ā€œESPserial.printā€ or ā€œESPserial.writeā€ but there are no data is coming to Serial Monitor of ESP-01.
Before someone asks why use this scheme, because UNO has FLASH & SRAM limit if I only use UNO (Blynk) and ESP-01 as shield (AT COMMAND), UNO can not accommodate sketch and run out of memory (Blynk library, sensor library etc). UNO has many pins, ESP-01 has a large FLASH memory but has few pins. so I divide the sketch into ESP-01 (Blynk Library and virtual pins commands) & UNO as brain (process sensor input output)
But why do people buy nasty ESP-01’s when you can buy a plug and play ESP for the same money?
The best internet resource for reading Serial data is Robin2’s tutorial at http://forum.arduino.cc/index.php?topic=39645020.
Combine this with the SimpleTimer and SoftwareSerial between ESP and Arduino as per https://www.arduino.cc/en/Tutorial/SoftwareSerialExample24 and you are good to go.
Well, your issue is NOT Blynk related… perhaps look at those other recommended forum & site…
Closing this topic.
@Fira As requested, I will reopen this so you can post your Blynk code here… I still suspect your issue is in your serial code, not due to a Blynk bug… but lets take a look and see.
Please format it properly after posting it…as required in the Welcome Topic.
Thanks man. sorry if i ask this, i’m new with this stuff,
this is my UNO’s sketch
// UNO Sketch Part Of ESP-01
#define ledPin 13
#define fanPin 12
#define serialbufferSize 15
// End of Constants
// Now the real varibles
#define debug 0
char inputBuffer[serialbufferSize]   ;
int serialIndex = 0; // keep track of where we are in the buffer
// End of real variables
SoftwareSerial ESPserial(7, 4); // RX | TX ESP-01 Connection
#include <IRremote.h>
IRsend irsend;
const unsigned int AC_irSignalONOFF[] PROGMEM = {9172, 4516, 600, 1684, 596, 1688, 596, 556, 592, 560, 592, 564, 592, 568, 592, 572, 592, 1692, 596, 548, 596, 1688, 596, 1692, 592, 560, 592, 564, 592, 568, 592, 568, 596, 560, 592, 548, 592, 552, 592, 1688, 596, 560, 596, 560, 592, 568, 592, 568, 592, 560, 592, 548, 592, 1688, 596, 556, 592, 560, 592, 1700, 596, 1700, 596, 568, 596, 1692, 596, 548, 596, 552, 592, 556, 592, 560, 596, 564, 592, 564, 596, 568, 592, 560, 592, 548, 596, 552, 592, 556, 596, 556, 596, 560, 596, 564, 596, 568, 592, 544, 592, 8064, 596, 1684, 596, 552, 592, 556, 592, 560, 592, 564, 592, 564, 596, 568, 596, 1692, 596, 1684, 592, 552, 596, 556, 592, 1696, 592, 1704, 592, 564, 596, 568, 592, 560, 592, 552, 592, 552, 592, 556, 596, 556, 596, 560, 596, 564, 592, 572, 592, 560, 596, 548, 592, 552, 592, 556, 592, 560, 592, 564, 592, 568, 592, 568, 596, 556, 596, 548, 592, 552, 592, 556, 596, 556, 596, 560, 596, 564, 596, 568, 596, 560, 592, 548, 596, 552, 592, 556, 592, 560, 592, 564, 592, 568, 592, 572, 596, 556, 596, 548, 596, 548, 596, 556, 592, 560, 592, 564, 592, 564, 596, 568, 592, 560, 592, 552, 592, 1688, 596, 1692, 596, 1692, 596, 564, 592, 1704, 596, 568, 592, 540, 596, 8064, 596, 552, 592, 552, 592, 556, 592, 560, 592, 564, 592, 568, 592, 568, 596, 556, 596, 1684, 596, 552, 592, 556, 592, 560, 592, 564, 592, 568, 592, 568, 596, 560, 596, 544, 596, 552, 592, 556, 592, 556, 596, 560, 592, 568, 592, 568, 596, 556, 596, 548, 592, 552, 592, 556, 592, 560, 592, 564, 592, 564, 596, 568, 592, 560, 592, 548, 596, 552, 592, 556, 592, 1696, 592, 564, 596, 564, 592, 572, 592, 560, 592, 548, 592, 552, 596, 552, 596, 556, 592, 564, 592, 568, 592, 568, 596, 556, 596, 1684, 596, 552, 592, 556, 592, 1696, 596, 564, 592, 568, 592, 568, 592, 544, 624}; //AnalysIR Batch Export (IRremote) - RAW
int khz = 38;
#include "DHT.h"
#define DHTTYPE DHT11
#define DHTPIN 10
DHT dht(DHTPIN, DHTTYPE);
  ESPserial.begin(9600);
  pinMode(ledPin,OUTPUT);
  pinMode(fanPin,OUTPUT);
  dht.begin();
 // Notice how the main loop is very simple and the functions
  // seperate the logic into easily manageable parts
  if (CheckSerial()) DoCommand(inputBuffer);
  readTemp ();
    // Do other stuff
boolean DoCommand(char * commandBuffer)
  // Standard way to handle commands
  if (strcmp(commandBuffer , "V0 1")==0) // ACPOWER ON OFF
    digitalWrite(ledPin,HIGH);
    sendRAW_Flash(AC_irSignalONOFF, sizeof(AC_irSignalONOFF)/sizeof(int),khz); //send AC signal #1 @ 33kHz
    delay(5000); //a good idea to have gaps between signals
    digitalWrite(ledPin,LOW);
    else if (strcmp(commandBuffer , "V4 1")==0) // FAN Relay
    //fanOn= !fanOn;
    digitalWrite(fanPin,1);
  else if (strcmp(commandBuffer , "V4 0")==0) // FAN Relay
    //fanOn= !fanOn;
    digitalWrite(fanPin,0);
  else {
    Serial.print("I dont understand you \nYou said: ");
    Serial.println(commandBuffer);
      //    Do some other work here
    //    and here
    //    and here
  // debug code after here
#if debug
  Serial.print("Free Ram = "); Serial.println(freeRam(), DEC);
#endif
return true;
Checks the serial input for a string, returns true once a '\n' is seen
users can always look at the global variable "serialIndex" to see if characters have been received already
boolean CheckSerial()
  boolean lineFound = false;
  // if there's any serial available, read it:
  while (ESPserial.available() > 0) {
    //Read a character as it comes in:
    //currently this will throw away anything after the buffer is full or the \n is detected
    char charBuffer = ESPserial.read();
      if (charBuffer == '\n') {
           inputBuffer[serialIndex] = 0; // terminate the string
           lineFound = (serialIndex > 0); // only good if we sent more than an empty line
           serialIndex=0; // reset for next line of data
         else if(charBuffer == '\r') {
           // Just ignore the Carrage return, were only interested in new line
         else if(serialIndex < serialbufferSize && lineFound == false) {
           /*Place the character in the string buffer:*/
           inputBuffer[serialIndex++] = charBuffer; // auto increment index
  }// End of While
  return lineFound;
}// End of CheckSerial()
#if debug
// check free ram
int freeRam ()
  extern int __heap_start, *__brkval;
  int v;
  return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
#endif
void sendRAW_Flash(const unsigned int * signalArray, unsigned int signalLength, unsigned char carrierFreq) {
  irsend.enableIROut(carrierFreq); //initialise the carrier frequency for each signal to be sent
  for (unsigned int i=0;i<signalLength;i++){
    //tmp=pgm_read_word_near(&signalArray[i]);
   // tmp=cleanPanasonic(tmp); //not needed
    if (i & 1) irsend.space(pgm_read_word_near(&signalArray[i]));
    else irsend.mark(pgm_read_word_near(&signalArray[i]));
  irsend.space(1);//make sure IR is turned off at end of signal
void readTemp (){
  if (isnan(t) ) {
    return;
  Serial.print(t);
  Serial.println(" *C ");
  ESPserial.println(t);
And this is my ESP-01 Sketch (that run Blynk)
char auth[] = "authTOKEN";
char ssid[] = "MYSSID";
char pass[] = "MYSSIDPASSWD";
  Blynk.begin(auth, ssid, pass, "local ip xxx.xxx.xxx.xxx");
BLYNK_WRITE(V0){ //AC-POWER//
  int pinValue = param.asInt();
  if (pinValue==1) {
  Serial.print("V0 ");
  Serial.println(pinValue);
BLYNK_WRITE(V4){ //FAN//
  if (pinValue==1) {
  Serial.print("V4 ");
  else{
//////////////////////////terminal////////////////
Blockquote
every thing is fine, i press button V0 on my phone and UNO can process it and turn my AC ON or OFF, if i Press V4 button on my phone UNO turn ON/OFF the Fan relay.
I just neeed grab ā€˜t’ (temperatur) value from uno and send it to ESP-01 as data, but Serial Monitor on ESP cannot showing it.( i’m stuck here). if i just use normal sketch i mean without Blynk Stuff, yes i can read it on ESP’s Serial Monitor, but if i run with Blynk library ESP’s Serial Monitor never Print/Showing incoming data from UNO.
sorry if this make you all get confused, English is not my primary languange, i hope you get what i mean to. tks
dear costas, i have bought them long time ago and maybe i have 3 or 4 pairs of them in my BOX TOYS. should I throw it all in the garbage? its not about the same value prices, it’s about how can we use them and optimized all of them.
I would certainly stop using them as you waste a lot of time with ESP-01’s.
@Fira In your Blynk sketch, you do not have any function running that would sense, and thus grab, any incoming serial data… that is why it is not ā€˜working’…
However, the problem you will run into if you implement such a scan of the incoming serial buffer, is that getting it to line up with serials timing while still not blocking Blynk’s own background processes.
It is not going to be easy at all… and is NOT something you will get much support for here, as it is well outside of what Blynk is designed to do in the first place.
I will make a recommendation to use another serial/i2C based data transfer library instead of trying to handle the Serial timing yourself… But again, it is NOT something you can get support for on this forum.
If I understand correctly, it will work with ESP, but only in one capacity, I think as Master not as Slave… so you will need to play around with it to see if it will work for you.
I will mark this topic solved, as an answer has technically been supplied - ā€œPossibly doable, but not officially supportedā€, but I will leave it open.
If you do manage to figure out how to combine the somewhat seperate worlds of Arduino/serial transfer and Blynk, feel free to share your progress… and even ask questions if you think they are applicable to the Blynk side of the operation.
Ok then, case closed. I’ll find another way. :slight_smile:
Thank you all.
thank you for suggesting using I2C instead of Serial connection.
Now I can read one, two even more sensors in arduino uno and display them in Blynk app, and control the uno output through I2C and virtual pin
Now my ESP-01 has many pins with the help of UNO as slave :slight_smile:
