NANO + shield ethernet ENC28J60 supported? [SOLVED]
Hello I’ve some projects that work on NANO + ENC28J60.
Can I still make them work with BLYNK 2.0 ?
I used this library for that :
#include <BlynkSimpleUIPEthernet.h> // ENC28J60 ethernet BLYNK library
Is it still supported by BLYNK 2.0 ?
PS: I ask because I stuck of course :wink:
//minimal code Blynk 2.0
#define BLYNK_TEMPLATE_ID “TMPLXnFLWBcV”
#define BLYNK_DEVICE_NAME “TEST1”
char auth[] = “blablabla”;
Blynk.begin(auth);
void loop(){
Detecting libraries used…
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/…
Alternatives for BlynkSimpleUIPEthernet.h: [Blynk@1.0.0]
ResolveLibrary(BlynkSimpleUIPEthernet.h)
→ candidates: [Blynk@1.0.0]
Alternatives for UIPEthernet.h: [UIPEthernet@2.0.6]
ResolveLibrary(UIPEthernet.h)
→ candidates: [UIPEthernet@2.0.6]
"C:\Program Files (x86)\Arduino\hardware\tools\avr/…
Alternatives for functional: []
ResolveLibrary(functional)
→ candidates: []
In file included from C:\Users\ahermant\Google�Drive (.be@gmail.com)\Electronique\ARDUINO\1.SKETCHS IN PROGRESS\libraries\Blynk\src/Blynk/BlynkApi.h:38:0,
from C:\Users\ahermant\Google�Drive (.be@gmail.com)\Electronique\ARDUINO\1.SKETCHS IN PROGRESS\libraries\Blynk\src/BlynkApiArduino.h:14,
from C:\Users\ahermant\Google�Drive (.be@gmail.com)\Electronique\ARDUINO\1.SKETCHS IN PROGRESS\libraries\Blynk\src/Adapters/BlynkEthernet.h:24,
from C:\Users\ahermant\Google�Drive (.be@gmail.com)\Electronique\ARDUINO\1.SKETCHS IN PROGRESS\libraries\Blynk\src/BlynkSimpleUIPEthernet.h:20,
from C:\Users\ahermant\AppData\Local\Temp…
C:\Users\ahermant\Google�Drive (.be@gmail.com)\Electronique\ARDUINO\1.SKETCHS IN PROGRESS\libraries\Blynk\src/Blynk/BlynkConsole.h:20:10: fatal error: functional: No such file or directory
#include
compilation terminated.
Utilisation de la bibliothèque Blynk version 1.0.0 dans le dossier: C:\Users\ahermant\Google Drive ()\Electronique\ARDUINO\1.SKETCHS IN PROGRESS\libraries\Blynk
Utilisation de la bibliothèque UIPEthernet version 2.0.6 dans le dossier: C:\Users\ahermant\Google Drive (.be@gmail.com)\Electronique\ARDUINO\1.SKETCHS IN PROGRESS\libraries\UIPEthernet
exit status 1
Erreur de compilation pour la carte Optiboot on 32-pin cpus
I think it’s related to Blynk 2.0 because I could transmit the sketch to the NANO just before upgrading the Blynk Library from 0.6.1 to 1.0.0.beta3
Where Can I find the right library 1.0.0 (no beta) ?
I tried this one →
but in my IDE when I add .ZIP →
"Specified folder/zip file does not contain a valid library
Please use the library fron the master branch. It will be released soon
Fine thank you
Working with →
I recommend the EthernetENC library for enc28j60. You can use it with Ethernet library examples of Blynk. only put `#include <EthernetENC.h>" at the top of the sketch
(I maintain UIPEthernet and EthernetENC)
Thanks for the info.
Is it better than “BlynkSimpleUIPEthernet.h” that works well?
I specially look for the lighter possible solution as NANO has not much memory available.
the settings can reduce flash and memory use:
https://github.com/jandrassy/EthernetENC/wiki/Settings
